Changes between Version 10 and Version 11 of GSoC/2016
Feb 21, 2016, 2:11:16 PM (8 years ago)
wenzeslaus
Martin's r67232 (pass giface to g.gui.* modules) implements most functionality requried for GUI plugins in a smart and simple way
  • GSoC/2016
    v10 v11
    181181 * Co-mentor: ?
    182182
    183 === GUI plugin system for GRASS GIS ===
    184
    185 GRASS GIS allows to install addons/extensions from GRASS Addons using `g.extension`. This works well for GRASS modules but it is not sufficient when things needs to be integral part of wxGUI.
    186
    187  * The main tasks are to write
    188   * a GUI which would manage and install the plugins,
    189   * mechanism which would load the installed and activated plugins and
    190   * an interface which plugins would use to communicate with GIS and integrate themselves into GUI.
    191  * GUI plugins should use the `g.extension` system in the background. The difference is that you may want to have more plugins installed but just a subset would be activated. Perhaps, GUI plugin manager can just take care of turning plugins off and on and setting for individual plugins while `g.extension` and wxGUI `g.extension` will take care of installation and related things (which should be possible in any case).
    192  * Some extensions may provide both GUI plugin and a standalone `g.gui.*` module (this is actually an ideal case).
    193  * Some GUI plugins may depend on a particular extension or even a Python package the extension installs.
    194  * Some GUI plugins may include or depend on some particular addons (group of extensions to install) or GUI toolbox (a file used to construct a menu).
    195  * Some plugins may include general files such as default configurations or images.
    196  * There is already an interface to communicate with GUI but it needs to be extended and improved. Also there should be a defined interface which plugin itself should provide (name, description, ...).
    197  * GUI plugin system should work the same for GUI plugins installed manually and installed using `g.extension`.
    198  * Several use cases should be explored and used as examples.
    199  * It would be good to consider (at least for the sake of real use case) turning some existing parts or wxGUI into plugins, e.g. vdigit, rdigit, iclass or various plots.
    200  * Bonus task is to extend `g.extension` in the way that it supports local source code (#1652) and individual extensions as source code in !GitHub (might be almost possible already using Subversion but on the level of the whole repository, not individual modules).
    201  * Language requirements: Python, wxPython
    202  * Mentor: ?
    203  * Co-mentors: Vaclav Petras, Anna Petrasova
    204
    205183=== Additional segmentation algorithms for i.segment ===
    206184
