Changes between Version 26 and Version 27 of GSoC/2016/Additional_segmentation_algorithms/weekly_report
- May 30, 2016, 7:06:53 PM (8 years ago)
v26 v27 47 47 === What do you plan on doing next week? === 48 48 * Write the meanshift.c module to implement the mean-shift algorithm based on pseudo-code. 49 * *Next week codes will be based on the essential functions of mean-shift algorithm. the fixed bandwidth and range width will be used and the codes need to implement the function which is able to separate objects(super-pixel).49 1. Next week codes will be based on the essential functions of mean-shift algorithm. the fixed bandwidth and range width will be used and the codes need to implement the function which is able to separate objects(super-pixel). 50 50 51 51 === Are you blocked on anything? ===
