Changes between Version 7 and Version 8 of AddOnsManagement
Nov 16, 2011, 2:02:25 AM (12 years ago)
martinl
  • AddOnsManagement
    v7 v8
    33== !AddOns XML file ==
    44
     5GRASS !AddOns metadata XML file can be created by [source:grass-addons/tools/addons/build-xml.py build-xml.py] Python script available from SVN. It's creating XML file `modules.xml` in `~/.grass6/addons` for GRASS 6 and in `~/.grass7/addons` for GRASS 7.
     7Example:
     8
     9{{{
     10#!xml
     11<?xml version="1.0" encoding="UTF-8"?>
     12<!DOCTYPE task SYSTEM "grass-addons.dtd">
     13<modules version=7.0.svn>
     14    <task name="d.mon2">
     15        <description>Starts a graphics display monitor which can be controlled from the command line.</description>
     16        <keywords>display,CLI</keywords>
     17    </task>
     18    <task name="i.points.auto">
     19        <description>Generate ground control points for image group to be rectified.</description>
     20        <keywords>imagery,ground control points</keywords>
     21    </task>
     22...
     23    <task name="v.unpack">
     24        <description>Unpacks a vector map packed with r.pack.</description>
     25        <keywords>vector,import,copying</keywords>
     26    </task>
     27</modules>
     28}}}
    529== Compile !AddOns on MS Windows ==
    630
