Changes between Version 13 and Version 14 of AddOnsManagement
- Nov 16, 2011, 2:11:34 AM (12 years ago)
AddOnsManagement
v13 v14 28 28 }}} 29 29 30 There is also available script called [source:grass-addons/tools/addons/compile-xml.sh compile-xml.sh] which compiles GRASS !AddOns modules for GRASS 6 and GRASS 7 and creates XML metadata file. This script simply calls `compile.sh` and `build-xml.py`. When running the script the main log file sis stored in `~/grass<version>/addons/make.log` and each modules logs in `~/.grass<version>/addons/log/<module>.log`. Beside that the script also print basic information about progress to standard output30 There is also available script called [source:grass-addons/tools/addons/compile-xml.sh compile-xml.sh] which compiles GRASS !AddOns modules for GRASS 6 and GRASS 7 and creates XML metadata file. This script simply calls `compile.sh` and `build-xml.py`. When running the script the main log file is stored in `~/grass<version>/addons/make.log` and each modules logs in `~/.grass<version>/addons/log/<module>.log`. Beside that the script also print basic information about progress to standard output 31 31 32 32 {{{
