Changes between Version 9 and Version 10 of AddOnsManagement
- Nov 16, 2011, 2:09:55 AM (12 years ago)
AddOnsManagement
v9 v10 28 28 }}} 29 29 30 There is also available script called [source:grass-addons/tools/addons/compile-xml.sh ] which compiles GRASS AddOns modules for GRASS 6 and GRASS 7 and creates XML metadata file. This script simply calls `compile.sh` and `build-xml.py`. When running this script the main log files is stored to `~/grass<version>/addons/make.log` and each modules logs to `~/.grass<version>/addons/log/<module>.log`. Beside that the script also print basic information about progress to standard output30 There is also available script called [source:grass-addons/tools/addons/compile-xml.sh compile-xml.sh] which compiles GRASS AddOns modules for GRASS 6 and GRASS 7 and creates XML metadata file. This script simply calls `compile.sh` and `build-xml.py`. When running this script the main log files is stored to `~/grass<version>/addons/make.log` and each modules logs to `~/.grass<version>/addons/log/<module>.log`. Beside that the script also print basic information about progress to standard output 31 31 32 32 {{{
