Changes between Version 1 and Version 2 of TracAdmin
- 06/10/10 13:36:24 (3 years ago)
TracAdmin
v1 v2 4 4 Trac is distributed with a powerful command-line configuration tool. This tool can be used to configure and customize your Trac-installation to better fit your needs. 5 5 6 Some of those operations can also be performed via the web interface thanks to the optional [http://trac.edgewall.org/wiki/WebAdmin WebAdmin] plugin, distributed separately for now.6 Some of those operations can also be performed via the ''Admin'' web interface, an updated version of the [http://trac.edgewall.org/wiki/WebAdmin WebAdmin] plugin now integrated within Trac (since version 0.11). 7 7 8 8 == Usage == 9 9 10 You can get a comprehensive list of the available options, commands and sub-commands by invoking `trac-admin` with the `help` command: 10 You can get a comprehensive list of the available options, commands and sub-commands by invoking `trac-admin` with the `help` command:. 11 11 {{{ 12 12 trac-admin help … … 31 31 }}} 32 32 33 To get help on a all the Wiki-related commands, run:33 To get help on all the Wiki-related commands, run: 34 34 {{{ 35 35 > help wiki 36 36 }}} 37 37 38 == Full Command Reference == 39 40 [[TracAdminHelp()]] 41 42 43 === Notes === 44 45 The `initenv` also supports an extra `--inherit` option, which can be used to specify the `[inherit] file` option at environment creation time so that only the options ''not'' already specified in the global configuration file will be written in the conf/trac.ini file of the newly created environment. 46 See TracIni#GlobalConfiguration. 47 48 Note that in version 0.11 of Trac, `initenv` lost an extra last argument `<templatepath>`, which was used in previous versions to point to the `templates` folder. If you are using the one-liner '`trac-admin /path/to/trac/ initenv <projectname> <db> <repostype> <repospath>`' in the above and getting an error that reads ''''`Wrong number of arguments to initenv: 4`'''', then this is because you're using a `trac-admin` script from an '''older''' version of Trac. 49 38 50 ---- 39 See also: TracGuide, TracBackup, TracPermissions, TracEnvironment, TracIni 51 See also: TracGuide, TracBackup, TracPermissions, TracEnvironment, TracIni, [trac:TracMigrate TracMigrate]
