Changes between Version 7 and Version 8 of RFC8
- May 16, 2019, 12:58:07 PM (5 years ago)
RFC8
v7 v8 20 20 The API also has some functional limitations: 21 21 * does not support M values 22 22 23 Downstream projects which are feeling pain: 24 * PDAL - had to use custom Point-In-Polygon because of overhead in passing points to GEOS 25 * Shapely - there are several allocations required to marshall from NumPY to GEOS 26 * PostGIS - hopefully this will allow calling GEOS without copying out of LWGEOM structure 27 23 28 === Goals 24 29
