Changes between Version 1 and Version 2 of RFC8
- May 16, 2019, 10:53:02 AM (5 years ago)
RFC8
v1 v2 1 = GEOS RFC 8: Improve Coordinate Sequence API (WIP)1 = GEOS RFC 8: Improve Coordinate Sequence API (WIP) 2 2 3 3 ||RFC 7: ||Improve CoordinateSequence API|| … … 6 6 ||Status: || || 7 7 8 This document proposes to modify the Coordinate Sequence API to improve performance and adaptiveness.8 This document proposes to modify the Coordinate Sequence API to improve performance and adaptiveness. 9 9 These improvements are (likely to be) breaking changes to the C++ API. 10 10 These may require extensions to the C API to be externally available, but should not result in breaking the current C API. … … 12 12 === Background 13 13 14 The Coordinate Sequence API as it stands imposes a large cost on clients.14 The Coordinate Sequence API as it stands imposes a large cost on clients. 15 15 * It requires copying coordinate list structures one or more times 16 16 * It imposes the cost of a Z ordinate even if not required by the client
