Changes between Version 5 and Version 6 of RFC4
- Mar 23, 2017, 3:24:16 AM (7 years ago)
RFC4
v5 v6 40 40 The `clang-format` is straightforward to run and can support development workflow as standalone tool or as one of many editor integrations. 41 41 42 Although no means to enforce the default formatting style are proposed, currently used CI services (eg. Travis CI) may be employed as a post-commit safety valve 43 - a clang-format lint failure as a compile break (eg. [https://github.com/mongodb/mongo/blob/master/buildscripts/clang_format.py clang_format.py] build script used by MongoDB). 42 Although no means to enforce the default formatting style are proposed, currently used CI services (eg. Travis CI) may be employed as a post-commit safety valve - a clang-format lint failure as a compile break (eg. [https://github.com/mongodb/mongo/blob/master/buildscripts/clang_format.py clang_format.py] build script used by MongoDB). 44 43 45 44 == Code Formatting Rules ==
