| 1 | === Windows === |
| 2 | |
| 3 | If you use [http://en.wikipedia.org/wiki/Microsoft_Visual_Studio Microsoft Visual C++] (7.1 or later) compiler, you can build GEOS using [http://msdn.microsoft.com/en-us/library/dd9y37ha.aspx NMAKE] program and provided makefile.vc files: |
| 4 | |
| 5 | {{{ |
| 6 | autogen.bat |
| 7 | nmake /f makefile.vc MSVC_VER=1400 |
| 8 | }}} |
| 9 | |
| 10 | where 1400 is version number of Visual C++ compiler, here [http://en.wikipedia.org/wiki/Visual_C%2B%2B Visual C++ 8.0] from [http://msdn.microsoft.com/en-us/library/ms950416.aspx Visual Studio 2005] (supported versions are 1300, 1310, 1400 and 1500). The ''autogen.bat'' step is required to generate a couple of header files (''note:'' autogen.bat is available in SVN only). |
| 11 | |
| 12 | In order to build debug configuration of GEOS, additional flag ''DEBUG=1'' is required: |
| 13 | {{{ |
| 14 | nmake /f makefile.vc MSVC_VER=1400 DEBUG=1 |
| 15 | }}} |
