Changes between Version 3 and Version 4 of BuildingOnUnixWithAutotools
- Jan 27, 2010, 3:31:07 PM (14 years ago)
v3 v4 9 9 10 10 11 == Configure == 12 13 Note, if you are building GEOS downloaded from SVN, you need to have [http://en.wikipedia.org/wiki/GNU_build_system Autotools] available in your system, so you can first generate ''./configure'' script using the following command: 14 11 15 {{{ 12 ./configure 13 make 14 make install 16 $ ./autogen.sh 15 17 }}} 16 18 17 Note, if you are building GEOS downloaded from SVN, you need to have [http://en.wikipedia.org/wiki/GNU_build_system Autotools] available in your system, so you can first generate ''./configure'' script using the following command: 19 Now, run configuration script: 20 18 21 {{{ 19 ./autogen.sh 22 $ ./configure 20 23 }}} 21 22 Then, you will be able to execute ''./configure'' and next the three commands listed above: ''make'' and ''make install''.23 24 24 25 For more details about configuration options run: … … 26 27 ./configure --help 27 28 }}} 29 30 == Build == 31 32 {{{ 33 $ make 34 }}} 35 36 == Test == 37 38 {{{ 39 $ make check 40 }}} 41 42 == Install == 43 44 {{{ 45 $ make install 46 }}}
