Changes between Version 13 and Version 14 of BufferRobustness
- Dec 6, 2011, 2:14:59 AM (12 years ago)
BufferRobustness
v13 v14 28 28 = Noding = 29 29 30 The image below shows difference between GEOS (yellow) and JTS (cyan) noding results with bufrob3_5input.30 The image below shows difference between GEOS (yellow) and JTS (cyan) noding results with [attachment:bufrob4.wkt] input. 31 31 There are two nodes in both version, only JTS is anchoring the line going down to the node on the left while GEOS is anchoring it to the node on the right. 32 32 It's interesting to note that the input (red line) is closer to GEOS result, not JTS.
