Changes between Version 12 and Version 13 of BufferRobustness
- Dec 6, 2011, 12:59:23 AM (12 years ago)
BufferRobustness
v12 v13 26 26 (ii) Output seems to have lost way too much precision. [[BR]] 27 27 28 = Noding = 29 30 The image below shows difference between GEOS (yellow) and JTS (cyan) noding results with bufrob3_5 input. 31 There are two nodes in both version, only JTS is anchoring the line going down to the node on the left while GEOS is anchoring it to the node on the right. 32 It's interesting to note that the input (red line) is closer to GEOS result, not JTS. 33 34 [[Image(JTS_GEOS_noding.png)]] 35 28 36 = Resources = 29 37 … … 35 43 I'm also attaching the JTS unit test which I'm using to compare GEOS/JTS runs. The test reads WKT from a file. 36 44 37 The image below shows difference between GEOS (yellow) and JTS (cyan) noding results with bufrob3_5 input.38 There are two nodes in both version, only JTS is anchoring the line going down to the node on the left while GEOS is anchoring it to the node on the right.39 It's interesting to note that the input (red line) is closer to GEOS result, not JTS.40 41 [[Image(JTS_GEOS_noding.png)]]
