Changes between Initial Version and Version 3 of Ticket #88
- Nov 22, 2007, 4:53:25 PM (16 years ago)
Ticket #88
- Property Status closed → reopened
- Property Reporter changed from to
- Property Component tests → Build/Install
- Property Summary Unused "Boost UTF" configuration → Unused Boost UTF configuration
- Property Priority 1 → minor
- Property Version 3.0.0 → svn-trunk
- Property Milestone imported → 3.0.0
- Property Resolution none
Ticket #88 – Description
initial v3 1 {{{2 1 Running ./configure script, user gets Boost UTF: no message, which may be a little confusing. 2 3 3 I suggest to remove it because GEOS does not use Boost UTF for Unit Tests. 4 }}}
