Changes between Initial Version and Version 3 of Ticket #158
- Nov 21, 2007, 2:14:05 PM (16 years ago)
Ticket #158
- Property Cc added
Ticket #158 – Description
initial v3 1 sample for XMLTester 2 1 3 {{{ 2 sample for XMLTester3 4 <run> 4 5 <!--precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/--> … … 6 7 <case> 7 8 <desc> 9 }}} 10 8 11 Test One Outer ring is returned instead of two outer rings. 9 12 One of the Polygons is not in the resultant set 13 {{{ 10 14 </desc> 11 15 <a> … … 24 28 <test> 25 29 <desc> 30 }}} 31 26 32 Buffer One Outer ring is returned instead of two outer rings. 27 33 One of the Polygons is not in the resultant set 34 {{{ 28 35 </desc> 29 36
