Changes between Initial Version and Version 8 of Ticket #120
- Nov 25, 2007, 10:58:21 PM (16 years ago)
Ticket #120
- Property Component Build scripts → Build/Install
- Property Priority 1 → major
- Property Version 3.0.0 → 2.2.3
- Property Milestone imported → 3.0.0
- Property Resolution none → fixed
Ticket #120 – Description
initial v8 1 {{{2 1 Using todays CVS snapshot, the following problems arise when running configure on my solaris 2.7 system: 3 2 4 > ./configure --help 5 > ./configure: syntax error at line 1622: `CAPI_VERSION_MAJOR=$' unexpected 3 {{{ 4 ./configure --help 5 ./configure: syntax error at line 1622: `CAPI_VERSION_MAJOR=$' unexpected 6 }}} 6 7 7 8 If I remove: 8 "$(($CAPI_INTERFACE_CURRENT-$CAPI_INTERFACE_AGE))" 9 and replace it with either "1" (the difference), or "$CAPI_INTERFACE_CURRENT-$CAPI_INTERFACE_AGE", 9 {{{ 10 $(($CAPI_INTERFACE_CURRENT-$CAPI_INTERFACE_AGE)) 11 }}} 12 and replace it with either ''1'' (the difference), or 13 {{{ 14 $CAPI_INTERFACE_CURRENT-$CAPI_INTERFACE_AGE 15 }}} 10 16 configure seems to work as expected. 11 17 12 I found that this problem also applies to version 2.2.3, but in 2.2.3 there was also another line with the same syntax that had to be "fixed". 13 }}} 18 I found that this problem also applies to version 2.2.3, but in 2.2.3 there was also another line with the same syntax that had to be ''fixed''
