| 44 | |
| 45 | The following widgets are ready for the release : |
| 46 | * editfeature_split |
| 47 | * editfeature_drag |
| 48 | * editfeature_copy |
| 49 | * editfeature_create |
| 50 | * editfeature_update |
| 51 | * featurepanel_customform |
| 52 | * featurepanel_selector |
| 53 | * geoextux_redliningpanel |
| 54 | * geoextux_shortcutcombo |
| 55 | * htwindow |
| 56 | * queryonclickwizard |
| 57 | * resultvectorlayer |
| 58 | * vectorlayer |
| 59 | * wfsfilterbuilder |
| 60 | |
| 61 | The following widgets need more work to be ready for the release : |
| 62 | * filetreepanel |
| 63 | * wmslayeradder |
| 64 | |
| 65 | |
| 66 | '''Widget excluded/deprecated/removed''' |
| 67 | |
| 68 | All the following widgets won't be part of the release. |
| 69 | |
| 70 | * ''excluded'' : keep the widget in trunk, but exclude it from the 1.0 release : |
| 71 | * featurepanel_attributeform |
| 72 | * editfeature_delete |
| 73 | * geoextux_wmsbrowser |
| 74 | * geoextux_geonamessearchcombo |
| 75 | * featurepanel_form |
| 76 | * ''deprecated'' : keep the widget in trunk, exclude it from 1.0 release and it as 'deprecated' (should no longer be used) : |
| 77 | * map |
| 78 | * mapfishlayertree |
| 79 | * mapfishrecenter |
| 80 | * ''removal'' : remove the widget source from trunk : |
| 81 | * legendpanel |
| 82 | * merge |
| 83 | * split |
| 84 | * quickzoom |
| 85 | * toolbar |
| 86 | * popup |
