Changes between Initial Version and Version 1 of TracChangeLog
May 4, 2015, 1:51:23 PM (9 years ago)
  • TracChangeLog
     1[[PageOutline(2-3)]]
     2= Change Log
     3This is a rough list of changes between released versions.
     5To see where Trac is going in future releases, see the [trac:roadmap Roadmap].
     8== 1.0.x Releases ==
     10== 1.0.5
     12//(24 March, 2015)//
     13
     14Trac 1.0.5 provides several fixes. The following are some highlights:
     15
     16 - Images are not rendered in the timeline ([trac:#10751]).
     17 - Git tags are shown in the browser view ([trac:#11964]).
     18 - Added support for `journal_mode` and `synchronous` pragmas
     19   in `sqlite:` database connection string ([trac:#11967]).
     20
     21See the detailed release notes for [[trac:wiki:TracDev/ReleaseNotes/1.0#MaintenanceReleases | 1.0.5]].
     23[trac:source:/tags/trac-1.0.5 View Tag] | [trac:milestone:1.0.5 View Milestone]
     25== 1.0.4
     27//(February 8, 2015)//
     28
     29Trac 1.0.4 contains a few fixes, including a fix for a regression in 1.0.3.
     30
     31 - Workflow action labels were not displayed unless name attribute
     32   was explicitly defined ([trac:#11930]).
     34See the detailed release notes for [[trac:wiki:TracDev/ReleaseNotes/1.0#MaintenanceReleases | 1.0.4]].
     35
     36[trac:source:/tags/trac-1.0.4 View Tag] | [trac:milestone:1.0.4 View Milestone]
     37
     38=== 1.0.3
     39
     40//(January 13, 2015)//
     41
     42Trac 1.0.3 is a maintenance release containing numerous fixes and minor
     43enhancements. The following are a few of the highlights:
     44
     45The following list contains only a few highlights:
     46
     47 - Notification is sent when adding an attachment to a ticket ([trac:#2259]).
     48 - Stylesheets and scripts are loaded during autopreview, resulting in proper
     49   syntax highlighting when code WikiProcessors are added ([trac:#10470]) and display
     50   of Workflow graphs without explicit autopreview ([trac:#10674]).
     51 - Merge changesets are shown as differences against first parent, resulting
     52   in less noisy changesets ([trac:#10740]).
     53 - Pygments 2.0 is supported ([trac:#11796]).
     54 - Fixed error when completing the `initenv` TracAdmin command ([trac:#11797]).
     55 - Performance improvement on systems with many thousands of authenticated
     56   users due to caching of Environment.get_known_users ([trac:#11868]).
     57 - Distribution metadata of wheel package is supported and displayed on the
     58   About page ([trac:#11877]).
     59 - … and more than 3 dozen total fixes!
     60
     61See the detailed release notes for [[trac:wiki:TracDev/ReleaseNotes/1.0#MaintenanceReleases | 1.0.3]].
     62
     63[trac:source:/tags/trac-1.0.3 View Tag] | [trac:milestone:1.0.3 View Milestone]
     64
     65
     66=== 1.0.2
     67
     68//(October 23, 2014)//
     69
     70Trac 1.0.2 contains a number of bug fixes and minor enhancements, as well as a major update for many translations.
     71
     72The following list contains only a few highlights:
     73
     74 - Subversion keywords are expanded and EOL substitutions made when viewing a file in the repository browser and when downloading a file ([trac:#717]).
     75 - Notification email is sent to the old owner when a ticket is reassigned ([trac:#2311]).
     76 - Ticket change history is updated when renaming and deleting a milestone, and when retargeting tickets to another milestone ([trac:#4582], [trac:#5658]).
     77 - Numerous fixes for the Authz permissions policy in the browser/repository ([trac:#10961], [trac:#11646]), wiki ([trac:#8976], [trac:#11067]), admin ([trac:#11069]) and report ([trac:#11176]) realms.
     78 - Multiple forms submits are disallowed ([trac:#10138]).
     79 - `ConfigurationError` is raised if any of the `permission_policies` can't be loaded, preventing possible information leakage due to internal and installation errors ([trac:#10285]).
     80 - Wiki toolbars can be disabled through a configuration setting ([trac:#10837])
     81 - The number of entries in a table is shown next to heading on applicable admin pages ([trac:#11027]).
     82 - //Cancel// buttons are consistently located on all pages ([trac:#11076]).
     83 - Focus is placed on a text element when an edit page is loaded ([trac:#11084]).
     84 - The //Edit conflict// and //Merge// warning messages are always visible in side-by-side edit mode ([trac:#11102]).
     85 - Improvements to the layout of the Report ([trac:#11106], [trac:#11664]) and Ticket pages ([trac:#11471]).
     86 - Genshi 0.7 compatibility ([trac:#11218]).
     87 - Numerous minor fixes for Git repository support.
     88 - … and more than a hundred more fixes!
     89
     90See the detailed release notes for [[trac:wiki:TracDev/ReleaseNotes/1.0#MaintenanceReleases | 1.0.2]] and [[trac:wiki:TracDev/ReleaseNotes/0.12#MaintenanceReleases | 0.12.6]] (as 1.0.2 contains all the fixes done for 0.12.6).
     91
     92[trac:source:/tags/trac-1.0.2 View Tag] | [trac:milestone:1.0.2 View Milestone]
     93
     94
     95=== 1.0.1
     96
     97//(February 1, 2013)//
     98
     99Trac 1.0.1 contains a number of bug fixes and minor enhancements, as well as a major update for many translations.
     100
     101The following list contains only a few highlights:
     102
     103 - Fix zip source download for large directories in Subversion repositories ([trac:#10840])
     104 - Performance improvement for the Roadmap, by caching milestone properties ([trac:#10879])
     105 - Added a ''select all'' checkbox to table of components for each plugin on the Plugins admin panel ([trac:#9609])
     106 - Restore the ''Modify'' link at the top of the ticket page, as it was in Trac 0.12 ([trac:#10856])
     107 - `ListOption` keeps values other than empty string and None in raw list as default ([trac:#10541])
     108 - Prevent possibility of multiple identical info or warning messages being presented to the user ([trac:#10987])
     109 - The !BatchModify select-all checkboxes are toggled with tri-state behavior when the ticket checkboxes are toggled ([trac:#10992])
     110 - Update the ticket changetime to the current time when deleting a ticket comment ([trac:#10486])
     111
     112See the detailed release notes for [[trac:wiki:TracDev/ReleaseNotes/1.0#MaintenanceReleases | 1.0.1]] and [[trac:wiki:TracDev/ReleaseNotes/0.12#MaintenanceReleases | 0.12.5]] (as 1.0.1 contains all the fixes done for 0.12.5).
     113
     114[trac:source:/tags/trac-1.0.1 View Tag] | [trac:milestone:1.0.1 View Milestone]
     115
     116
     117=== '''1.0 'Cell' '''
     118
     119//(September 7, 2012)//
     120
     121Trac 1.0 is a major release adding refreshed user interface and improved DVCS repository support as the most visible changes.
     122
     123The following list contains only a few highlights:
     124 - The default theme looks more modern, especially on recent browsers (no effort has been made to make it look better on older browsers like IE6 or 7)
     125 - The [TH:GitPlugin] has been donated by Herbert Valerio Riedel to the Trac project (many thanks!) and is now maintained here as an optional component
     126 - As a consequence, the Subversion support has been moved below `tracopt.versioncontrol` as well
     127 - The Git and Mercurial log view feature a visualization of the branching structure
     128 - Usability improvements for the tickets, with a better support for conflict detection and resolution
     129 - Integration of the [TH:BatchModifyPlugin], contributed by Brian Meeker (many thanks!) and is now maintained there as a default component
     130 - jQuery/UI integration, featuring a date picker for date fields
     131 - Improved integration with Pygments syntax highlighting
     132 - ... and numerous smaller features added and bugs fixed since 0.12!
     133
     134See the full list in [trac:wiki:TracDev/ReleaseNotes/1.0 1.0].
     135
     136[[trac:source:/tags/trac-1.0 View Tag]] | [[trac:milestone:1.0 View Milestone]]
     137
     138== 0.12.x Releases
     139
     140=== 0.12.6
     141
     142//(October 23, 2014)//
     143
     144Trac 0.12.6 contains fixes for a few issues:
     145 - Subversion blame would fail for a path with URL-encoded characters ([trac:#10386]), a lower-case drive letter on Windows ([trac:#10514]), or a non-ascii filename with Subversion 1.7 ([trac:#11167]).
     146 - Improved performance rendering `svn:mergeinfo` properties in browser view ([trac:#8459]) and changeset view ([trac:#11219]).
     147 - Query with many custom fields would fail ([trac:#11140]).
     148 - Zip archive had a timestamp with no timezone information ([trac:#11162]).
     149 - Failure or incorrect ranges rendering log TracLinks ([trac:#11308], [trac:#11346]).
     150 - Textareas in ticket view did not wrap correctly in IE 11 ([trac:#11376]).
     151 - Emails were not being obfuscated in owner field on CSV export from ticket and query pages ([trac:#11594]).
     152 - Locale data was not being included in egg in Distribute 0.6.29 and later ([trac:#11640]).
     153 - Deleting a milestone would not delete its attachments ([trac:#11672]).
     154 - Added support for Babel 1.0 and later ([trac:#11258], [trac:#11345]).
     155 - Added support for `ConfigObj` 5.0 and later ([trac:#11498]).
     156 - … and dozens more fixes!
     157
     158See the detailed release notes for [[trac:wiki:TracDev/ReleaseNotes/0.12#MaintenanceReleases | 0.12.6]].
     159
     160[trac:source:/tags/trac-0.12.6 View Tag] | [trac:milestone:0.12.6 View Milestone]
     161
     162=== 0.12.5
     163
     164//(January 15, 2013)//
     165
     166Trac 0.12.5 contains fixes for a few issues:
     167 - upload of .mht files ([Wikipedia:MHTML] web page archive files) now works ([trac:#9880])
     168 - more robust parsing of attachment URLs ([trac:#10280]) and uploaded file names ([trac:#10850])
     169 - lots of improvement to the date formatting code, which is now much more robust when timezone and daylight saving time computations are involved ([trac:#10768], [trac:#10863], [trac:#10864], [trac:#10912], [trac:#10920])
     170 - no longer generate invalid JSON encoded data with Python 2.4 and 2.5 ([trac:#10877])
     171 - ... and fix a couple more minor defects ([trac:#10967], [trac:#10892], [trac:#10923], [trac:#10858], [trac:#10835])
     172
     173[trac:source:/tags/trac-0.12.5 View Tag] | [trac:milestone:0.12.5 View Milestone]
     174
     175=== 0.12.4
     176
     177//(September 7, 2012)//
     178
     179Trac 0.12.4 contains only a handful of minor fixes.
     180
     181[trac:source:/tags/trac-0.12.4 View Tag] | [trac:milestone:0.12.4 View Milestone]
     182
     183=== 0.12.3 ===
     184
     185//(February 6, 2012)//
     186
     187Trac 0.12.3 contains a few minor fixes and a few minor features.
     188 - compatibility with Subversion 1.7 ([trac:#10414])
     189 - easier troubleshooting of common startup errors ([trac:#10024])
     190 - jQuery upgraded to 1.4.4 ([trac:#10001])
     191 - improve fine-grained permission handling in the source browser ([trac:#9976], [trac:#10208], [trac:#10110])
     192 - added compatibility with MySQL 5.5.3 utf8mb4 databases ([trac:#9766])
     193 - ... and dozens more fixes!
     194
     195[trac:source:/tags/trac-0.12.3 View Tag] | [trac:milestone:0.12.3 View Milestone]
     196
     197=== 0.12.2
     198
     199//(January 31, 2011)//
     200
     201Trac 0.12.2 contains a few minor fixes and a few minor features.
     202
     203This list contains only a few highlights:
     204 - install: improved robustness of Trac installation if Babel is
     205   installed after the fact ([trac:#9439], [trac:#9595], [trac:#9961])
     206 - notifications: support for Asian character width ([trac:#4717])
     207 - roadmap: fix display of progress bar in some corner cases ([trac:#9718])
     208   and respect the overall_completion milestone group setting ([trac:#9721])
     209 - reports: reports and queries look much better, as the columns now
     210   keep the same width across groups; the absence of word wrapping in
     211   reports has been fixed ([trac:#9825])
     212 - web admin: improved layout ([trac:#8866], [trac:#9963])
     213 - web: it's now possible to log in different Trac instances sharing
     214   the same URL prefix (e.g. /project and /project-test) ([trac:#9951])
     215
     216[trac:source:/tags/trac-0.12.2 View Tag] | [trac:milestone:0.12.2 View Milestone]
     217
     218=== 0.12.1
     219
     220//(October 9, 2010)//
     221
     222Trac 0.12.1 contains a few important performance improvements, some minor fixes and a few minor features.
     223
     224This list contains only a few highlights:
     225 - db: improve concurrency behavior ([trac:#9111])
     226 - fcgi: add an environment variable `TRAC_USE_FLUP` to control the usage of flup vs. bundled _fcgi.py (defaults to 0, i.e. use bundled as before)
     227 - svn authz: improve compatibility with svn 1.5 format ([trac:#8289])
     228 - milestone: allow to set the time for the due date ([trac:#6369], [trac:#9582])
     229 - ticket: fixes for the CC: property ([trac:#8597], [trac:#9522])
     230 - notification: improved the formatting of ticket fields in notification e-mails ([trac:#9484], [trac:#9494])
     231 - i18n: added a configuration option to set the default language ([trac:#8117])
     232 - several fixes for upgrade ([trac:#9400], [trac:#9416], [trac:#9483], [trac:#9556])
     233
     234[trac:source:/tags/trac-0.12.1 View Tag] | [trac:milestone:0.12.1 View Milestone]
     235
     236=== ''' 0.12 'Babel' '''
     237
     238//(June 13, 2010)//
     239
     240Trac 0.12 is a major release introducing i18n and multiple repository support as the most visible changes.
     241
     242The following list contains only a few highlights:
     243 - The user interface is translated in a dozen of languages, provided the [Babel:] package is installed
     244 - Multiple repositories can be associated to a single Trac environment; the repositories can be of heterogeneous types (svn, hg, git, darcs...)
     245 - Usability improvements for the Wiki, with a nice side-by-side edit mode with automatic preview
     246 - Richer Wiki syntax, with much improved support for tables, partial [trac:WikiCreole] compatibility and numerous smaller improvements
     247 - Usability improvements for the Ticket module, with automatic preview of comments while you type and possibility to edit or remove them later
     248 - Improved Custom Queries (time fields, multiple disjoint conditions, a.k.a. OR queries)
     249 - Timeline filtering by user
     250 - ... and numerous smaller features added and bugs fixed since 0.11!
     251
     252[trac:source:/tags/trac-0.12 View Tag] | [trac:milestone:0.12 View Milestone]
     253
     254== Older Releases
     255
     256For releases prior to 0.12, see [trac:TracChangeLog@95].
