Changes between Version 9 and Version 10 of z3950_sru
- Dec 17, 2009, 11:09:42 AM (14 years ago)
z3950_sru
v9 v10 24 24 not applied to this part of the software) 25 25 26 The proposal is thus to undertake an overhaul of the Z39.50 part of the code andto update the JZKit library to version 3 and to implement a26 The proposal is thus to undertake an overhaul of the Z39.50 part of the code, to update the JZKit library to version 3 and to implement a 27 27 SRU webinterface in the process. 28 28 … … 48 48 49 49 SRU interface implemented as jeeves service. (http://127.0.0.1:8080/geonetwork/srv/en/portal.sru?operation=searchretrieve&version=1.2&query=title%20any%20WMO ). 50 51 The spring application-context had to be integrated into Geonetwork. 52 53 JZKit configuration files need a directory in the classpath. 50 54 51 55 JZKit is dependent on the following libraries
