Changes between Version 6 and Version 7 of targetnamespace
- Dec 2, 2008, 6:12:08 AM (15 years ago)
targetnamespace
v6 v7 10 10 === Introduction === 11 11 12 The target namespace of an XML Schema is the namespace of documents that are described by that schema. Documents described by the schemas used in the CSW-ebRIM Registry Service specification ( OGC 07-110r2 and OGC 07-144r2) are in the WRS namespace; although there is a slight difference is the actual namespace between the schema for the ebRim profile of CSW (targetnamespace: !http://www.opengis.net/cat/wrs/1.0) and the schema for the Basic extension package (targetnamespace: !http://www.opengis.net/cat/wrs).12 The target namespace of an XML Schema is the namespace of documents that are described by that schema. Documents described by the schemas used in the CSW-ebRIM Registry Service specification ([http://portal.opengeospatial.org/files/?artifact_id=27092 OGC 07-110r2] and [http://portal.opengeospatial.org/files/?artifact_id=27093 OGC 07-144r2]) are in the WRS namespace; although there is a slight difference is the actual namespace between the schema for the ebRim profile of CSW (targetnamespace: !http://www.opengis.net/cat/wrs/1.0) and the schema for the Basic extension package (targetnamespace: !http://www.opengis.net/cat/wrs). 13 13 14 14 The XML Schema for the ebRim profile of CSW is included in OGC 07-110r2 and reprinted on this wiki [wiki:CSWebRIMXSD here].
