Changes between Version 2 and Version 3 of synch_lang
Show
04/03/09 02:43:58 (4 years ago)
ticheler
  • synch_lang
    v2 v3
    1616{{{java -cp WEB-INF/lib/geonetwork.jar:WEB-INF/lib/jeeves.jar:WEB-INF/lib/jdom.jar org.fao.geonet.apps.!CheckLocalizedFiles loc/ en > output_file.txt}}}
    1717
    18 You can also run the application for other folders containing localized files. For instance part of InterMap or those that come with a metadata schema. Just change the {{{loc/}}} part with a reference to the folder you want to compare. So for instance:
     18You can also run the application for other folders containing localized files. For instance part of !InterMap or those that come with a metadata schema. Just change the {{{loc/}}} part with a reference to the folder you want to compare. So for instance:
    1919
    2020{{{java -cp WEB-INF/lib/geonetwork.jar:WEB-INF/lib/jeeves.jar:WEB-INF/lib/jdom.jar org.fao.geonet.apps.CheckLocalizedFiles xml/schemas/iso19139/loc/ en > ~/localization_errors_19139.txt}}}
