Changes between Version 1 and Version 2 of registers
Oct 25, 2011, 7:26:38 PM (12 years ago)
simonp
  • registers
    v1 v2
    2727
    2828=== Voting History ===
    29  * Vote proposed by X on Y, result was +/-n (m non-voting members).
    30
    31 ----
     29 * Vote not yet proposed.
    3230
    3331== Motivations ==
    34 The current configuration is .... A change to ....
     32
     33Currently:
     34
     35 * Vocabularies, codelists and thesaurii are held in static files external to the GeoNetwork catalog. The process by which items in these registers are modified, updated, superseded or retired are invisible as the formats they are held in do not support capture of this information.
     36 * Metadata records that use items from these registers usually do so by referencing an external document (eg. http://asdd.ga.gov.au/asdd/profileinfo/anzlic-theme.xml)
     37 * Often the codelist has been converted to yet another format for use in the GeoNetwork editor (eg. the ISO19139 codelists in http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml are converted to a codelists.xml file for use in GeoNetwork). Propagating changes to a codelist
     38
     39The motivation for this proposal is to capture register changes in the register, make registers transportable between catalogs through harvesting, and converge access to one register format.
    3540
    3641== Proposal ==
    37 An in depth proposal can be found here : link
    38 ...
     42
     43
    3944
    4045=== Backwards Compatibility Issues ===
