Changes between Initial Version and Version 1 of proposals/vocabTransformation
Oct 19, 2012, 8:33:25 AM (12 years ago)
fxp
  • proposals/vocabTransformation
     1= Configurable thesaurus concept selection =
     3|| '''Date''' || 2011-10-26 ||
     4|| '''Contact(s)''' || Francois Prunayre ||
     5|| '''Status''' || Being discussed, in progress, initial implementation in progress ||
     6|| '''Assigned to release''' || 2.9.x ||
     7|| '''Resources''' || Available ||
     8|| '''Ticket #''' || #XYZ ||
     9|| '''Github dev branch ''' || https://github.com/fxprunayre/core-geonetwork/commits/feature/registers-transformations ||
     10
     11== Overview ==
     12
     13Configure transformation in order to use thesaurus to add different types of elements (eg. use a concept to add a keyword or an extent).
     14
     15=== Proposal Type ===
     16 * '''Type''': GUI Change, Schema Change
     17 * '''App''': !GeoNetwork
     18 * '''Module''': Schema
     19
     20=== Links ===
     21 * '''Documents''':
     23=== Voting History ===
     24 * Vote not yet proposed.
     25
     26== Motivations ==
     27
     28== Proposal ==
     29
     30
     31=== Adding transformations ===
     32
     33XSL transformations mapped raw format for keyword to a XML snippet of the target schema. They are defined per schema plugins in a convert/thesaurus-transformation.xsl.
     34
     35{{{
     36        <xsl:include href="blanks/metadata-schema01/convert/thesaurus-transformation.xsl"/>
     37}}}
     38This transformation file define as many template as required:
     39{{{
     40<xsl:template name="to-iso19139-keyword">
     41                <xsl:param name="withAnchor" select="false()"/>
     42                <xsl:param name="withXlink" select="false()"/>
     43
     44                <gmd:MD_Keywords>
     45...
     46}}}
     47
     48Naming convention for template: to-{schemaIdentifier}-{outputDescription}.
     49
     50
     51The raw format is the following and remain unchanged with previous !GeoNetwork release:
     52{{{
     53<keyword>
     54  <selected>false</selected>
     55  <id>0</id>
     56  <value language="eng">Agricultural and aquaculture facilities</value>
     57  <definition language="eng"/>
     58  <defaultLang>eng</defaultLang>
     59  <thesaurus>
     60     <key>external.theme.inspire-theme</key>
     61     <title>GEMET - INSPIRE themes, version 1.0</title>
     62     <date>2008-06-01</date>
     63     <type>theme</type>
     64     <url>http://localhost:8080/geonetwork/srv/en/thesaurus.download?ref=external.theme.inspire-theme</url>
     65  </thesaurus>
     66  <uri>http://rdfdata.eionet.europa.eu/inspirethemes/themes/22</uri>
     67  <values>
     68     <value language="eng">Agricultural and aquaculture facilities</value>
     69  </values>
     70  <definitions>
     71     <definition language="eng"/>
     72  </definitions>
     73</keyword>
     74}}}
     75
     76=== Using the transformation ===
     78A transformation parameter is added to the xml.keyword.get service in order to choose the mapping to use. For example, to create a gmd:descriptiveKeyword section in ISO19139, 3 transformations are defined:
     79 * ISO19139 with CharacterString:
     80http://localhost:8080/geonetwork/srv/eng/xml.keyword.get?thesaurus=external.theme.inspire-theme&id=http://rdfdata.eionet.europa.eu/inspirethemes/themes/22,http://rdfdata.eionet.europa.eu/inspirethemes/themes/30&multiple=true&transformation=to-iso19139-keyword
     81 * ISO19139 with Anchor:
     82http://localhost:8080/geonetwork/srv/eng/xml.keyword.get?thesaurus=external.theme.inspire-theme&id=http://rdfdata.eionet.europa.eu/inspirethemes/themes/22,http://rdfdata.eionet.europa.eu/inspirethemes/themes/30&multiple=true&transformation=to-iso19139-keyword-with-anchor
     83 * ISO19139 with Anchor: TODO
     84http://localhost:8080/geonetwork/srv/eng/xml.keyword.get?thesaurus=external.theme.inspire-theme&id=http://rdfdata.eionet.europa.eu/inspirethemes/themes/22,http://rdfdata.eionet.europa.eu/inspirethemes/themes/30&multiple=true&transformation=to-iso19139-keyword-with-anchor
     85
     86 * ISO19139 extent element :
     87http://localhost:8080/geonetwork/srv/eng/xml.keyword.get?thesaurus=external.place.regions&id=http://geonetwork-opensource.org/regions%232&multiple=true&transformation=to-iso19139-extent
     88
     89
     90=== Define which transformation to use according to the element type ===
     91
     92{{{
     93<!--
     94registerAssociation : hold associations between elements ISO element and the thesaurus to propose for that element.
     95-->
     96<registerAssociation registerId="local://thesaurus/external.place.regions" element="gmd:extent"/>
     97<registerAssociation registerId="local://thesaurus/external.place.regions" element="gmd:descriptiveKeywords"/>
     98<registerAssociation registerId="local://thesaurus/external.theme.inspire-theme" element="gmd:descriptiveKeywords"/>
     100<!--
     101registerTransformation : hold associations between elements ISO element and the template to use for its transformation from SKOS format.
     102-->
     103<registerTransformation element="gmd:extent" xslTpl='to-iso19139-gmd_extent'/>
     104<registerTransformation element="gmd:descriptiveKeywords" xslTpl='to-iso19139-keywords'/>
     105<registerTransformation element="gmd:descriptiveKeywords" xslTpl='to-iso19139-keywords-with-anchor'/>
     106<registerTransformation element="gmd:descriptiveKeywords" xslTpl='to-iso19139-keywords-with-xlink'/>
     107}}}
     108
     109A new service is added to retrieve the list of transformation:
     110 * schema.register.get?schema={schemaIdentifier}&element={elementName}
     111
     112=== Editor widget for adding elements ===
     113
     114Widget configuration:
     115 * renderTo : null if popup mode, identifier of the DOM element for inline mode
     116 * elementType : element type to edit (eg. gmd:descriptiveKeywords)
     117 * transformations : array of transformations (use to override the server configuration)
     118 * thesaurus : array of thesaurus (use to override the server configuration)
     119 * defaultThesaurus : thesaurus identifier to select by default (null by default)
     120 * keywords : Store of select keyword (uri, value, thesaurus, xmin, ymin, xmax, ymax)
     121 * lang : search language (default is GUI language)
     122 * allowSearch : display search filter or not (default is true)
     123 * searchOnLoad : trigger search on load
     124
     125
     126{{{
     127<div class='thesaurusPicker' config='...'/>
     128}}}
     129
     130
     131=== Backwards Compatibility Issues ===
     132
     133
     134=== New libraries added ===
     135
     136None.
     137
     138== Risks ==
     139
     140Everything involves some element of risk....
     141
     142== Participants ==
     143
     144 * Francois Prunayre
     145 * Others?
