Changes between Initial Version and Version 1 of proposals/SubTemplates
May 27, 2011, 3:09:11 AM (13 years ago)
fxp
  • proposals/SubTemplates
     1= Sub-templates =
     3|| '''Date''' || 2011/05/25 ||
     4|| '''Contact(s)''' || Francois, Simon ||
     5|| '''Last edited''' || ||
     6|| '''Status''' || draft ||
     7|| '''Assigned to release''' || 2.7.0 ||
     8|| '''Resources''' || Available ||
     9|| '''Ticket''' || #XYZ ||
     10
     11== Overview ==
     12
     13This proposal aims to provide the capability to handle sub-templates. Sub-templates are XML fragment of metadata records.
     14
     15Example for a point of contact in ISO19139:
     16{{{
     17<?xml version="1.0" encoding="UTF-8"?>
     18<gmd:pointOfContact xmlns:gts="http://www.isotc211.org/2005/gts" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:gml="http://www.opengis.net/gml">
     19        <gmd:CI_ResponsibleParty>
     20                <gmd:individualName>
     21                        <gco:CharacterString>NAME</gco:CharacterString>
     22                </gmd:individualName>
     23                <gmd:organisationName>
     24                        <gco:CharacterString>Name of the responsible organization</gco:CharacterString>
     25                </gmd:organisationName>
     26                <gmd:positionName>
     27                        <gco:CharacterString>Function performed by the responsible party</gco:CharacterString>
     28                </gmd:positionName>
     29                <gmd:role>
     30                        <gmd:CI_RoleCode codeList="./resources/codeList.xml#CI_RoleCode" codeListValue="pointOfContact"/>
     31                </gmd:role>
     32        </gmd:CI_ResponsibleParty>
     33</gmd:pointOfContact>
     34}}}
     35
     36Sub-templates are designed to be inserted into metadata records using 2 mode:
     37 * one time link with copy/paste action
     38 * permanent link with XLink.
     39
     40
     41
     42=== Proposal Type ===
     43 * '''Type''': Metadata
     44 * '''App''': !GeoNetwork
     45 * '''Module''': Admin, Editor
     46
     47=== Links ===
     48 * '''Documents''':
     49 * '''Email discussions''':
     50 * '''Other wiki discussions''':
     51
     52=== Voting History ===
     53 * Vote proposed by  on  , result was
     54
     55----
     56
     57== Proposal ==
     58
     59Sub-templates are:
     60 * XML document
     61 * stored in the Metadata table with
     62  * value 's' for the template column (reminder: 'y' is for template, 'n' is for metadata)
     63  * root element is stored in the root column. It allows us to know the type of sub-templates (and where it could be inserted in an existing record)
     64  * schema is defined like metadata or template documents
     65 * indexed using Lucene identified by field _isTemplate='s'
     66 * imported through the metadata record import administration page ?
     67 * similar to metadata document for privileges management
     68
     69In the user interface, sub-templates are accessible through:
     70 * a sub-templates manager in the administration
     71 * a popup selection mechanism in the metadata editor (like CRS, Thesaurus)
     72
     73Types of sub-templates:
     74 * contact
     75 * ... extent ?
     76
     77=== Manage sub-templates ===
     78
     79A service is added to return the list of available sub-templates available.
     80 * getTypes method: return the list of available sub-templates available
     81
     82Sub-templates actions:
     83 * insert : Use the metadata insert form to create a sub-template
     84 * update/delete : Use the sub-template manager
     85 * search : Use any search services with _isTemplate='s'
     86 * privileges : Define privileges for the sub-template.
     87
     88=== Using sub-templates in the editor ===
     89
     90TODO : basically using similar popup like CRS or Thesaurus
     91 * full text search
     92 * select one or more elements
     93 * add (as XLink or using simple copy)
     94 * could this be generic ?
     95  * add selector according to the types available in the catalogue (using the _root info) ?
     96
     97=== Questions: ===
     98
     99 * do we need more than full text indexing ?
     100 * should we use metadata import page to import sub template ? or a custom one ?
     101 * how to autodetect schema for templates ? - maybe we need a specific import page to set schema value. or if user set subtemplate for the type, then schema is mandatory ?
     102 * we always edit in advanced mode - at least non flat mode to provide all schema elements ?
     103 * Subtemplate model
     104  * we need a title for all types of subtemplate (to be display in search). Where/how to configure ?
     105   * Quid on extent ? using description which is not mandatory ?
     106
     107Future feature:
     108 * Capability to extract subtemplate from existing record (cf. ReusableObjectStrategy in geocat.ch)?
     109
     110
     111=== Backwards Compatibility Issues ===
     112None.
     113
     114=== New libraries added ===
     115None.
     116
     117
     118== Participants ==
     119 * Francois Prunayre
     120 * Simon Pigot
