Changes between Version 2 and Version 3 of proposals/LuceneOnlySearch
Show
10/31/11 08:12:40 (19 months ago)
Fxp
  • proposals/LuceneOnlySearch
    v2 v3
    2222
    2323
     24The Lucene only search is available through the "q" service which return XML response. The widgets interface could be configured to use this service instead of xml.search (ie. classic user interface will not change).
     25
    2426=== Proposal Type ===
    2527 * '''Type''': Lucene, Core Change
    2628 * '''App''': !GeoNetwork
    27  * '''Module''': !LuceneSearcher
     29 * '''Module''': !LuceneSearcher, Widgets
    2830
    2931=== Links ===
    3638== Motivations ==
    3739
    38  * Performance improvements.
     40 * Performance improvements: search could be 10 to 20 time faster and better support concurrent users.
     41
     42The following charts compare 3 services:
     43 * xml.search in default mode (ie with DB, with XSL)
     44 * xml.search in fast mode (ie. with DB, no XSL)
     45 * q service (#485) which dump all index fields (ie. no DB, no XSL)
     46
     47
     48=== Number of concurrent users increasing ===
    3949
    4050[[Image(geonetwork-pure-lucene-search-perf.png)]]
     51
     52
     53=== number of records returned per page ===
    4154
    4255[[Image(geonetwork-pure-lucene-search-perf-with-larger-number-of-results.png)]]
    128141None.
    129142
     143== Missing features ==
     144
     145 * Support multilingual metadata: classic mechanism to use GUI language and fallback to main language is not implemented for this service. It should be part of the multilingual metadata indexing proposal (http://trac.osgeo.org/geonetwork/wiki/MultilingualIndexMechanism) and require more work.
     146
     147
     148
    130149== Risks ==
    131150
