Changes between Version 7 and Version 8 of pluginprofiles
Show
10/25/10 04:18:39 (3 years ago)
simonp
  • pluginprofiles
    v7 v8
    5858 * move templates and sample-data into schema directory and change gast and other code to use the !SchemaManager to obtain paths to these directories
    5959 * add services that accept a schema zip file directly or URL of a schema zip file or UUID of a metadata record with schema zip archive attached, which retrieve and unpack the schema from the zip file into the schemaPlugins directory, and adds the schema to the list of schemas that !GeoNetwork knows about (no config changes required) - add, delete and update
     60
     61[[Image(Screenshot-admin-screen-schema.png)]]
     62
     63[[Image(Screenshot-adding-a-schema.png)]]
    6064
    6165=== Backwards Compatibility Issues ===
