Changes between Version 1 and Version 2 of persistence
- Jun 19, 2008, 5:18:36 PM (16 years ago)
persistence
v1 v2 13 13 || '''Status''' || draft || 14 14 || '''Assigned to release''' || to be determined || 15 || '''Resources''' || ??? Indicate if the required resources are available to complete the proposal||15 || '''Resources''' || ??? || 16 16 17 17 == Overview == 18 18 19 Short description of the improvement proposal. 20 ... 19 Suggestions for using a persistence framework. 21 20 22 21 === Proposal Type === 23 22 * '''Type''': GUI Change, Core Change, Module Change, Guideline and project governance procedures, ... 24 23 * '''App''': !GeoNetwork 25 * '''Module''': eg. Harvester, Kernel, Data Manager, Metadata Import, Lucene Index, Search Interface ...24 * '''Module''': Data Manager, DB access 26 25 27 26 === Links === … … 31 30 32 31 === Voting History === 33 * Vote proposed by X on Y, result was +/-n (m non-voting members).32 * No vote requested yet. 34 33 35 34 ---- 36 35 37 36 == Motivations == 38 The current configuration is .... A change to .... 37 Snip from the aforementioned email discussion: 39 38 39 > As of version 2.2.0 the GeoNetwork application cannot be deployed to a 40 > cluster. Existing deployments probably haven't gotten to the size where 41 > clustering is necessary, but if this were to happen, deployment to a cluster 42 > will fail. 40 43 41 As of version 2.2.0 the GeoNetwork application cannot be deployed to a 42 cluster. Existing deployments probably haven't gotten to the size where 43 clustering is necessary, but if this were to happen, deployment to a cluster 44 will fail. 44 > There are several reasons for this. Firstly, the application is storing 45 > non-Serializable objects in the !HttpSession. Not terribly difficult to fix 46 > but is still a show stopper. 45 47 46 There are several reasons for this. Firstly, the application is storing 47 non-Serializable objects in the HttpSession. Not terribly difficult to fix 48 but is still a show stopper. 48 > Secondly, and this is the real killer, the current mechanism of generating 49 > unique primary keys in jeeves.util.!SerialFactory will fail in a cluster due 50 > to duplicate primary keys. The !SerialFactory caches the max primary key 51 > values for each table. In a cluster multiple !SerialFactory instances will 52 > exist and are oblivious of each other. The first node to insert a record will 53 > succeed, other nodes will fail. 49 54 50 Secondly, and this is the real killer, the current mechanism of generating 51 unique primary keys in jeeves.util.SerialFactory will fail in a cluster due 52 to duplicate primary keys. The SerialFactory caches the max primary key 53 values for each table. In a cluster multiple SerialFactory instances will 54 exist and are oblivious of each other. The first node to insert a record will 55 succeed, other nodes will fail. 55 > Geoscience Australia has deployed GeoNetwork using Oracle. The correct way to 56 > deal with this in Oracle is to use a SEQUENCE. This requires generating 57 > Oracle specific SQL, something the project has avoided doing. 56 58 57 Geoscience Australia has deployed GeoNetwork using Oracle. The correct way to 58 deal with this in Oracle is to use a SEQUENCE. This requires generating 59 Oracle specific SQL, something the project has avoided doing. 60 61 In my humble opinion, if GeoNetwork is to achieve its full potential it needs 62 to be scalable. Issues like in memory key generation prevent this from 63 occurring. The bottom line is you need to need to be DB independent but 64 scalable. The project should seriously consider the adoption of a persistence 65 framework such as Hibernate. 59 > In my humble opinion, if GeoNetwork is to achieve its full potential it needs 60 > to be scalable. Issues like in memory key generation prevent this from 61 > occurring. The bottom line is you need to need to be DB independent but 62 > scalable. The project should seriously consider the adoption of a persistence 63 > framework such as Hibernate. 64 65 We'll also have to get independent from the spatial dbms used, so a persistence framework with spatial capabilities would be the better choice. 66 66 67 67 == Proposal == 68 An in depth proposal can be found here : link 69 ... 68 69 The suggested framework is Hibernate Spatial. 70 ...etc 71 70 72 71 73 === Backwards Compatibility Issues === 72 74 73 75 == Risks == 76 * It has been reported (aaime) that H does use its cache a lot. When a search gives an high number of results, the cache could generate an !OutOfMemory error. This may be avoided using directQueries, which somehow don't use cache. It's a good solutions for read-only queries (and catalog queries are like that). This kind of queries may have drawbacks in terms of unusable lazy loads (an internal H feature), and this could lead to potential problems with an ebRIM based schema, because of the high number of related objects. This issue has been reported on an old H version (about start of 2007), so it may not be valid any longer. 74 77 75 78 == Participants == 76 * List of participants and role (if necessary) in current GIP 79 * ETj 80 * Some ideas and discussions with A Aime, S Giannecchini, A Fabiani. 77 81
