Changes between Version 13 and Version 14 of metadataworkflow
- 12/12/11 17:42:24 (17 months ago)
metadataworkflow
v13 v14 13 13 Metadata records have a lifecycle that typically goes through one or more states. eg when a record is created and edited by an 'Editor' user it is in the 'Draft' state. Whilst it is reviewed by a 'Content Reviewer' user it would typically be in a 'Submitted' state. If the record is found to be complete and correct by the 'Content Reviewer' it would be in the 'Approved' state and may be made available for casual search and harvest by assigning privileges to the !GeoNetwork 'All' group. Eventually, the record may be superseded or replaced and the state would be 'Retired'. At present !GeoNetwork doesn't have a formal process by which the state of the record can be captured. This makes it more difficult to manage and administer metadata records. This proposal adds: 14 14 15 * state (or status) to records in !GeoNetwork: 'Unknown', 'Draft', 'Submitted', 'Approved', 'Rejected', 'Retired'. The status is held in a database table called !MetadataStatus. Extra states can be added to this table if required. 15 * state (or status) to records in !GeoNetwork: 'Unknown', 'Draft', 'Submitted', 'Approved', 'Rejected', 'Retired'. The status is held in a database table called !MetadataStatus. Extra states can be added to this table if required. A user interface has been added to allow the user to set these status values. 16 16 * two status change action hooks (in Java) that can be used by sites to provide specific behaviours: The first action (statusChange) is called when status is changed by a user eg. when 'Draft' records are set to 'Submitted' and could be used for example to send notifications to other users affected by this change. The second action (onEdit) is called when a record is edited and saved and could be used for example to reset records with an 'Approved' status to 'Draft' status. A default set of actions is provided. These can be customised or replaced by sites that wish to provide different or more extensive behaviour. 17 17 * an extra 'Restrict to' search option in the 'Advanced Search' tab that allows the user to search on 'Status'
