Changes between Version 16 and Version 17 of interop_matrix
- Jun 22, 2011, 2:01:58 AM (13 years ago)
interop_matrix
v16 v17 3 3 ||'''Server'''||'''GN version and build'''||'''Harvesting'''||'''Harvester URL'''||'''Client'''||'''Does harvest work?'''||'''Error'''||'''Protocol & version'''||'''Comments'''|| 4 4 ||ESRI !GeoPortal 1.1.0.41||2.7 Build 7809||CSW||http://localhost:5555/geoportal/csw?request=GetCapabilities&service=CSW&version=2.0.2||GeoNetwork||Yes||||CSW 2.0.2||ESRI Geoportal installed on localhost with ISO19115 records. NOTE: If using 'Free text' in search criteria, specify search term with '%' wildcard characters eg. %ESRI% would search for records which have the string ESRI anywhere in their content.|| 5 ||GeoNetwork||2.7 Build 7809||CSW||http://localhost:8080/geonetwork/srv/en/csw?request=GetCapabilities&service=CSW&version=2.0.2||ESRI !GeoPortal 1.1.0.41||Yes||||CSW 2.0.2||ESRI Geoportal harvesting from GeoNetwork using CSW synchronization with Profile 'GeoNetwork CSW 2.0.2 APISO' selected. NOTE: (1) Set the CSW Server Configuration values in Administration->CSW Server Configuration on GeoNetwork before attempting synchronization otherwise you will receive funky error messages in the ESRI Geoportal Add screen about 'title' not set etc. (2)Records must validate against schemas otherwise they will be rejected by the ESRI Geoportal (code says something about isDraft but not sure yet how to tell Geoportal to harvest them as draft/unfinished). ||5 ||GeoNetwork||2.7 Build 7809||CSW||http://localhost:8080/geonetwork/srv/en/csw?request=GetCapabilities&service=CSW&version=2.0.2||ESRI !GeoPortal 1.1.0.41||Yes||||CSW 2.0.2||ESRI Geoportal harvesting from GeoNetwork using CSW synchronization with Profile 'GeoNetwork CSW 2.0.2 APISO' selected. '''NOTE:''' '''(1)''' Set the CSW Server Configuration values in Administration->CSW Server Configuration on GeoNetwork before attempting synchronization otherwise you will receive funky error messages in the ESRI Geoportal Add screen about 'title' not set etc. '''(2)''' Records must validate against schemas otherwise they will be rejected by the ESRI Geoportal (code says something about isDraft but not sure yet how to tell Geoportal to harvest them as draft/unfinished). || 6 6 ||GeoNetwork||2.7 Build 7809||OAIPMH||http://localhost:8080/geonetwork/srv/en/oaipmh||ESRI !GeoPortal 1.1.0.41||Yes||||OAIPMH 2.0||ESRI Geoportal harvesting from GeoNetwork using OAIPMH synchronization with prefix iso19139 and set 'datasets' || 7 7
