Changes between Version 13 and Version 14 of interop_matrix
- Jun 22, 2011, 1:41:54 AM (13 years ago)
interop_matrix
v13 v14 3 3 ||'''Server'''||'''GN version and build'''||'''Harvesting'''||'''!GetCapabilities URL'''||'''Client'''||'''Does harvest work?'''||'''Error'''||'''CSW version'''||'''Comments'''|| 4 4 ||ESRI !GeoPortal 1.1.0.41||2.7 Build 7809||CSW||http://localhost:5555/geoportal/csw?request=GetCapabilities&service=CSW&version=2.0.2||GeoNetwork||Yes||||2.0.2||ESRI Geoportal installed on localhost with ISO19115 records. NOTE: If using 'Free text' in search criteria, specify search term with '%' wildcard characters eg. %ESRI% would search for records which have the string ESRI anywhere in their content.|| 5 ||GeoNetwork||2.7 Build 7809||CSW||http://localhost:8080/geonetwork/srv/en/csw?request=GetCapabilities&service=CSW&version=2.0.2||ESRI !GeoPortal 1.1.0.41||Yes||||2.0.2||ESRI Geoportal harvesting from GeoNetwork using CSW synchronization with Profile 'GeoNetwork CSW 2.0.2 APISO' selected. NOTE: Set the CSW Server Configuration values in Administration->CSW Server Configuration on GeoNetwork before attempting synchronization otherwise you will receive funky error messages in the ESRI Geoportal Add screen about 'title' not set etc.||5 ||GeoNetwork||2.7 Build 7809||CSW||http://localhost:8080/geonetwork/srv/en/csw?request=GetCapabilities&service=CSW&version=2.0.2||ESRI !GeoPortal 1.1.0.41||Yes||||2.0.2||ESRI Geoportal harvesting from GeoNetwork using CSW synchronization with Profile 'GeoNetwork CSW 2.0.2 APISO' selected. NOTE: (1) Set the CSW Server Configuration values in Administration->CSW Server Configuration on GeoNetwork before attempting synchronization otherwise you will receive funky error messages in the ESRI Geoportal Add screen about 'title' not set etc. (2) Records must validate against schemas otherwise they will be rejected by the ESRI Geoportal (code says something about isDraft but not sure yet how to tell Geoportal to harvest them as draft/unfinished). || 6 6 ||Spanish SDI||2.2 build r1291||CSW||http://www.idee.es/csw/servlet/cswservlet?Request=GetCapabilities||Custom||No||The server does not support GET requests; !GeoNetwork is using GET for the !GetCapabilities request||2.0.0||Basic web client: http://www.idee.es/csw/client.html|| 7 7 ||BAFG - Germany||2.2 build r1291||CSW||SOAP service, cannot be accessed from !GeoNetwork harvesting||Custom-SOAP||No||This Server only supports SOAP, direct requests such as !GetCapabilities are not available||???||WSDL (Axis): http://geoportal.bafg.de/csw/services/CSW20_Discovery_SOAP_Port?wsdl||
