Changes between Version 8 and Version 9 of ebXMLObjectModel
Jul 21, 2008, 8:28:30 AM (16 years ago)
heikki
  • ebXMLObjectModel
    v8 v9
    4444In order to efficiently create an XML binding, that is to say the ability to marshal and unmarshal XML documents, the Java Beans implementation is decorated with a [http://jibx.sourceforge.net/ JiXB binding]. JiXB was chosen over other binding frameworks such as [http://xmlbeans.apache.org/ XMLBeans], [http://www.castor.org/ Castor] and [https://jaxb.dev.java.net/ JAXB] because of its [https://bindmark.dev.java.net/old-index.html high performance], ease of use, and non-intrusive programming model.
    4545
    46 An sample of code that marshals a !RegistryObject document is the following. This and similar code you can find in the Object Model's unit test suite.
     46A sample of code that marshals a !RegistryObject document is the following. This and similar code you can find in the Object Model's unit test suite.
    4747
    4848 {{{
     49
    4950
    5051    IBindingFactory bfact = BindingDirectory.getFactory(RegistryObject.class);
