Changes between Version 22 and Version 23 of ebXMLObjectModel
Jul 21, 2008, 9:10:06 AM (16 years ago)
heikki
  • ebXMLObjectModel
    v22 v23
    3535Note: the Access Control section of the Information Model specification is not (yet) part of the implementation.
    3636
    37 The implementation is complemented with a suite of unit tests, for each of the objects that may be used as a top-level element in an ebXML document. The unit tests are written in the well-known [http://www.junit.org/ Junit framework]. The testcases are for each of these objects, a test for marshalling, and a test for unmarshalling. As we're dealing with XML the tests use the complimentary test library [http://xmlunit.sourceforge.net/ XML Unit]. This allows a.o. to ignore differences in whitespace and the order of elements in the XML where that should be ignored. The test suite will be incorporated into the Continuous Integration build process.
     37The implementation is complemented with a suite of unit tests, for each of the objects that may be used as a top-level element in an ebXML document. The unit tests are written in the well-known [http://www.junit.org/ Junit framework]. The testcases are for each of these objects, a test for marshalling, and a test for unmarshalling. As we're dealing with XML the tests use the complimentary test library [http://xmlunit.sourceforge.net/ XML Unit]. This allows a.o. to ignore differences in whitespace and the ordering of elements and attributes in the XML where that should be ignored. The test suite will be incorporated into the Continuous Integration build process.
    3838
    3939
