Changes between Version 35 and Version 36 of codesprint/201106-bolsena
Jun 19, 2011, 7:23:29 AM (13 years ago)
simonp
  • codesprint/201106-bolsena
    v35 v36
    123123|| Better documentation of GeoNetwork api || Would be very useful for those wishing to get started on making enhancements and modifications ||
    124124|| Support for schemaPlugins || Added in proposal http://trac.osgeo.org/geonetwork/wiki/pluginprofiles but may need additional work to support services that relate to a schema/profile - see above ||
     125|| Support for time zones in temporal search terms || Calendar widget needs to include timezone specification ||
     126|| Better support for selecting default editor tab || Although this appears to be supported in config-gui.xml, strange things happen if you switch off the simple mode editor for example (this is actually a bug I think) ||
     127|| Harvested records are not obvious in search results || Should appear in search results as visual indicator ||
     128|| Massive thumbnail support || ||
     129|| Editor tabs to be redesigned to suggest entry workflow || Should suggest a workflow through the metadata rather than an arbitrary grouping of elements based on the standard - an example of what is desired can be seen in the ANZMETLite editor (written in VB.Net) - download from http://geonetwork.globaldial.com/testdownloads/ANZMETLite_MCP_ALA.zip (warning: will only work under windows) ||
     130|| More thought on how to integrate GeoNetwork with existing business systems in an organisation || Particularly important if GeoNetwork is seen as a tool for managing an organisations metadata as opposed to simply publishing an organisations metadata to the rest of the world ||
    125131
    126132
