Changes between Version 1 and Version 2 of TracTicketsCustomFields
- Jun 10, 2010, 1:36:22 PM (14 years ago)
v1 v2 17 17 * label: Descriptive label. 18 18 * value: Default value. 19 * order: Sort order placement. (Determines relative placement in forms.) 19 * order: Sort order placement. (Determines relative placement in forms with respect to other custom fields.) 20 * format: Either `plain` for plain text or `wiki` to interpret the content as WikiFormatting. (''since 0.11.3'') 20 21 * '''checkbox''': A boolean value check box. 21 22 * label: Descriptive label. … … 25 26 * label: Descriptive label. 26 27 * options: List of values, separated by '''|''' (vertical pipe). 27 * value: Default value ( Item #, starting at 0).28 * value: Default value (one of the values from options). 28 29 * order: Sort order placement. 29 30 * '''radio''': Radio buttons. Essentially the same as '''select'''. 30 31 * label: Descriptive label. 31 32 * options: List of values, separated by '''|''' (vertical pipe). 32 * value: Default value ( Item #, starting at 0).33 * value: Default value (one of the values from options). 33 34 * order: Sort order placement. 34 35 * '''textarea''': Multi-line text area. … … 38 39 * rows: Height in lines. 39 40 * order: Sort order placement. 41 * format: Either `plain` for plain text or `wiki` to interpret the content as WikiFormatting. (''since 0.11.3'') 40 42 41 43 === Sample Config === … … 48 50 test_two = text 49 51 test_two.label = Another text-box 50 test_two.value = Just a default value 52 test_two.value = Default [mailto:joe@nospam.com owner] 53 test_two.format = wiki 51 54 52 55 test_three = checkbox … … 57 60 test_four.label = My selectbox 58 61 test_four.options = one|two|third option|four 59 test_four.value = 262 test_four.value = two 60 63 61 64 test_five = radio 62 65 test_five.label = Radio buttons are fun 63 66 test_five.options = uno|dos|tres|cuatro|cinco 64 test_five.value = 167 test_five.value = dos 65 68 66 69 test_six = textarea … … 75 78 === Reports Involving Custom Fields === 76 79 77 The SQL required for TracReports to include custom ticket fields is relatively hard to get right. You need a `JOIN` with the `ticket_custom` field for every custom field that should be involved.80 Custom ticket fields are stored in the `ticket_custom` table, not in the `ticket` table. So to display the values from custom fields in a report, you will need a join on the 2 tables. Let's use an example with a custom ticket field called `progress`. 78 81 79 The following example includes a custom ticket field named `progress` in the report: 82 {{{ 83 #!sql 84 SELECT p.value AS __color__, 85 id AS ticket, summary, owner, c.value AS progress 86 FROM ticket t, enum p, ticket_custom c 87 WHERE status IN ('assigned') AND t.id = c.ticket AND c.name = 'progress' 88 AND p.name = t.priority AND p.type = 'priority' 89 ORDER BY p.value 90 }}} 91 '''Note''' that this will only show tickets that have progress set in them, which is '''not the same as showing all tickets'''. If you created this custom ticket field ''after'' you have already created some tickets, they will not have that field defined, and thus they will never show up on this ticket query. If you go back and modify those tickets, the field will be defined, and they will appear in the query. If that's all you want, you're set. 92 93 However, if you want to show all ticket entries (with progress defined and without), you need to use a `JOIN` for every custom field that is in the query. 80 94 {{{ 81 95 #!sql … … 96 110 Note in particular the `LEFT OUTER JOIN` statement here. 97 111 112 === Updating the database === 113 114 As noted above, any tickets created before a custom field has been defined will not have a value for that field. Here's a bit of SQL (tested with SQLite) that you can run directly on the Trac database to set an initial value for custom ticket fields. Inserts the default value of 'None' into a custom field called 'request_source' for all tickets that have no existing value: 115 116 {{{ 117 #!sql 118 INSERT INTO ticket_custom 119 (ticket, name, value) 120 SELECT 121 id AS ticket, 122 'request_source' AS name, 123 'None' AS value 124 FROM ticket 125 WHERE id NOT IN ( 126 SELECT ticket FROM ticket_custom 127 ); 128 }}} 129 130 If you added multiple custom fields at different points in time, you should be more specific in the subquery on table {{{ticket}}} by adding the exact custom field name to the query: 131 132 {{{ 133 #!sql 134 INSERT INTO ticket_custom 135 (ticket, name, value) 136 SELECT 137 id AS ticket, 138 'request_source' AS name, 139 'None' AS value 140 FROM ticket 141 WHERE id NOT IN ( 142 SELECT ticket FROM ticket_custom WHERE name = 'request_source' 143 ); 144 }}} 145 98 146 ---- 99 147 See also: TracTickets, TracIni
