Changes between Version 1 and Version 2 of TracPlugins
- Jun 10, 2010, 1:36:22 PM (14 years ago)
TracPlugins
v1 v2 2 2 [[TracGuideToc]] 3 3 4 Since version 0.9, Trac supports plugins that extend the built-in functionality. The plugin functionality is based on the [http://trac.edgewall.org/wiki/TracDev/ComponentArchitecture component architecture].4 Since version 0.9, Trac supports [trac:PluginList plugins] that extend the built-in functionality. The plugin functionality is based on the [trac:TracDev/ComponentArchitecture component architecture]. 5 5 6 6 == Requirements == 7 7 8 8 To use egg based plugins in Trac, you need to have [http://peak.telecommunity.com/DevCenter/setuptools setuptools] (version 0.6) installed. 9 10 Plugins can also consist of a single `.py` file dropped into either the environment or global `plugins` directory ''(since [milestone:0.10])''.11 9 12 10 To install `setuptools`, download the bootstrap module [http://peak.telecommunity.com/dist/ez_setup.py ez_setup.py] and execute it as follows: … … 17 15 If the `ez_setup.py` script fails to install the setuptools release, you can download it from [http://www.python.org/pypi/setuptools PyPI] and install it manually. 18 16 17 Plugins can also consist of a single `.py` file dropped into either the environment or global `plugins` directory ''(since [milestone:0.10])''. See TracIni#GlobalConfiguration . 18 19 19 == Installing a Trac Plugin == 20 20 21 21 === For a Single Project === 22 22 23 Plugins are packaged as [http://peak.telecommunity.com/DevCenter/PythonEggs Python eggs]. That means they are ZIP archives with the file extension `.egg`. If you have downloaded a source distribution of a plugin, you can run: 23 Plugins are packaged as [http://peak.telecommunity.com/DevCenter/PythonEggs Python eggs]. That means they are ZIP archives with the file extension `.egg`. 24 25 If you have downloaded a source distribution of a plugin, and want to build the `.egg` file, follow this instruction: 26 * Unpack the source. It should provide a setup.py. 27 * Run: 24 28 {{{ 25 29 $ python setup.py bdist_egg 26 30 }}} 27 to build the `.egg` file. 31 32 Then you will have a *.egg file. Examine the output of running python to find where this was created. 28 33 29 34 Once you have the plugin archive, you need to copy it into the `plugins` directory of the [wiki:TracEnvironment project environment]. Also, make sure that the web server has sufficient permissions to read the plugin egg. 35 36 To uninstall a plugin installed this way, remove the egg from `plugins` directory and restart web server. 30 37 31 38 Note that the Python version that the egg is built with must … … 35 42 recognized. 36 43 44 Note also that in a multi-project setup, a pool of Python interpreter instances will be dynamically allocated to projects based on need, and since plugins occupy a place in Python's module system, the first version of any given plugin to be loaded will be used for all the projects. In other words, you cannot use different versions of a single plugin in two projects of a multi-project setup. It may be safer to install plugins for all projects (see below) and then enable them selectively on a project-by-project basis. 45 37 46 === For All Projects === 38 47 39 48 ==== With an .egg file ==== 40 49 41 Some plugins (such as [ http://trac.edgewall.org/wiki/WebAdmin WebAdmin]) are downloadable as a `.egg` file which can be installed with the `easy_install` program:50 Some plugins (such as [trac:SpamFilter SpamFilter]) are downloadable as a `.egg` file which can be installed with the `easy_install` program: 42 51 {{{ 43 easy_install Trac WebAdmin-0.1.1dev_r2765-py2.3.egg52 easy_install TracSpamFilter 44 53 }}} 45 54 … … 48 57 If Trac reports permission errors after installing a zipped egg and you would rather not bother providing a egg cache directory writable by the web server, you can get around it by simply unzipping the egg. Just pass `--always-unzip` to `easy_install`: 49 58 {{{ 50 easy_install --always-unzip Trac WebAdmin-0.1.1dev_r2765-py2.3.egg59 easy_install --always-unzip TracSpamFilter-0.2.1dev_r5943-py2.4.egg 51 60 }}} 52 61 You should end up with a directory having the same name as the zipped egg (complete with `.egg` extension) and containing its uncompressed contents. 53 62 54 Trac also searches for globally installed plugins under `$prefix/share/trac/plugins` ''(since 0.10)''.63 Trac also searches for globally installed plugins ''(since 0.10)'', see TracIni#GlobalConfiguration. 55 64 56 65 ==== From source ==== 57 66 58 If you downloaded the plugin's source from Subversion, or a source zip file you can install it using the included `setup.py`:67 `easy_install` makes installing from source a snap. Just give it the URL to either a Subversion repository or a tarball/zip of the source: 59 68 {{{ 60 $ python setup.py install 69 easy_install http://svn.edgewall.com/repos/trac/sandbox/spam-filter 61 70 }}} 62 71 63 72 ==== Enabling the plugin ==== 64 Unlike plugins installed per-environment, you'll have to explicitly enable globally installed plugins via [wiki:TracIni trac.ini]. This is done in the `[components]` section of the configuration file, for example:73 Unlike plugins installed per-environment, you'll have to explicitly enable globally installed plugins via [wiki:TracIni trac.ini]. This also applies to plugins installed in the path specified in the `[inherit] plugins_dir` configuration option. This is done in the `[components]` section of the configuration file, for example: 65 74 {{{ 66 75 [components] 67 webadmin.* = enabled76 tracspamfilter.* = enabled 68 77 }}} 69 78 70 The name of the option is the Python package of the plugin. This should be specified in the documentation of the Plugin, but can also be easily find outby looking at the source (look for a top-level directory that contains a file named `__init__.py`.)79 The name of the option is the Python package of the plugin. This should be specified in the documentation of the plugin, but can also be easily discovered by looking at the source (look for a top-level directory that contains a file named `__init__.py`.) 71 80 72 Note: After installing the plugin, you may need to restart Apache. 81 Note: After installing the plugin, you need to restart your web server. 82 83 ==== Uninstalling ==== 84 85 `easy_install` or `python setup.py` does not have an uninstall feature. Hower, it is usually quite trivial to remove a globally installed egg and reference: 86 1. Do `easy_install -m [plugin name]` to remove references from `$PYTHONLIB/site-packages/easy-install.pth` when the plugin installed by setuptools. 87 1. Delete executables from `/usr/bin`, `/usr/local/bin` or `C:\\Python*\Scripts`. For search what executables are there, you may refer to `[console-script]` section of `setup.py`. 88 1. Delete the .egg file or folder from where it is installed, usually inside `$PYTHONLIB/site-packages/`. 89 1. Restart web server. 90 91 If you are uncertain about the location of the egg, here is a small tip to help locate an egg (or any package) - replace `myplugin` with whatever namespace the plugin uses (as used when enabling the plugin): 92 {{{ 93 >>> import myplugin 94 >>> print myplugin.__file__ 95 /opt/local/python24/lib/site-packages/myplugin-0.4.2-py2.4.egg/myplugin/__init__.pyc 96 }}} 73 97 74 98 == Setting up the Plugin Cache == 75 99 76 Some plugins will need to be extracted by the Python eggs runtime (`pkg_resources`), so that their contents are actual files on the file system. The directory in which they are extracted defaults to the home directory of the current user, which may or may not be a problem. You can however override the default location using the `PYTHON_EGG_CACHE` environment variable.100 Some plugins will need to be extracted by the Python eggs runtime (`pkg_resources`), so that their contents are actual files on the file system. The directory in which they are extracted defaults to '.python-eggs' in the home directory of the current user, which may or may not be a problem. You can however override the default location using the `PYTHON_EGG_CACHE` environment variable. 77 101 78 102 To do this from the Apache configuration, use the `SetEnv` directive as follows: … … 100 124 }}} 101 125 102 ''Note: this requires the `mod_env` module''126 ''Note: !SetEnv requires the `mod_env` module which needs to be activated for Apache. In this case the !SetEnv directive can also be used in the `mod_python` Location block.'' 103 127 104 For [wiki:TracFastCgi FastCGI], you'll need to `-initial-env` option, or whatever is provided by your web server for setting environment variables. 128 For [wiki:TracFastCgi FastCGI], you'll need to `-initial-env` option, or whatever is provided by your web server for setting environment variables. 129 130 ''Note: that if you already use -initial-env to set the project directory for either a single project or parent you will need to add an additional -initial-env directive to the !FastCgiConfig directive. I.e. 131 132 {{{ 133 FastCgiConfig -initial-env TRAC_ENV=/var/lib/trac -initial-env PYTHON_EGG_CACHE=/var/lib/trac/plugin-cache 134 }}} 105 135 106 136 === About hook scripts === … … 127 157 === Is the plugin enabled? === 128 158 159 129 160 If you install a plugin globally (i.e. ''not'' inside the `plugins` directory of the Trac project environment) you will have to explicitly enable it in [TracIni trac.ini]. Make sure that: 130 161 * you actually added the necessary line(s) to the `[components]` section 131 162 * the package/module names are correct 132 * if you're reference a module (as opposed to a class), you've appended the necessary “.*”133 163 * the value is “enabled", not e.g. “enable” 134 164 135 165 === Check the permissions on the egg file === 136 166 137 Trac must of course be able to read the file. Yeah, you knew that ;-)167 Trac must be able to read the file. 138 168 139 169 === Check the log files === 140 170 141 Enable [TracLogging logging] in Trac, set the log level to `DEBUG` and then watch the log file for messages about loading plugins. 171 Enable [wiki:TracLogging logging] and set the log level to `DEBUG`, then watch the log file for messages about loading plugins. 172 173 === Verify you have proper permissions === 174 175 Some plugins require you have special permissions in order to use them. [trac:WebAdmin WebAdmin], for example, requires the user to have TRAC_ADMIN permissions for it to show up on the navigation bar. 176 177 === Is the wrong version of the plugin loading? === 178 179 If you put your plugins inside plugins directories, and certainly if you have more than one project, you need to make sure that the correct version of the plugin is loading. Here are some basic rules: 180 * Only one version of the plugin can be loaded for each running Trac server (ie. each Python process). The Python namespaces and module list will be shared, and it cannot handle duplicates. Whether a plugin is `enabled` or `disabled` makes no difference. 181 * A globally installed plugin (typically `setup.py install`) will override any version in global or project plugins directories. A plugin from the global plugins directory will be located before any project plugins directory. 182 * If your Trac server hosts more than one project (as with `TRAC_ENV_PARENT_DIR` setups), then having two versions of a plugin in two different projects will give uncertain results. Only one of them will load, and the one loaded will be shared by both projects. Trac will load the first found - basically from the project that receives the first request. 183 * Having more than one version listed inside Python site-packages is fine (ie. installed with `setup.py install`) - setuptools will make sure you get the version installed most recently. However, don't store more than one version inside a global or project plugins directory - neither version number nor installed date will matter at all. There is no way to determine which one will be located first when Trac searches the directory for plugins. 184 185 === If all of the above failed === 186 187 OK, so the logs don't mention plugins, the egg is readable, the python version is correct ''and'' the egg has been installed globally (and is enabled in the trac.ini) and it still doesn't work or give any error messages or any other indication as to why? Hop on the [trac:IrcChannel IrcChannel] and ask away. 142 188 143 189 ---- 144 See also TracGuide, [ http://trac.edgewall.org/wiki/PluginList plugin list], [http://trac.edgewall.org/wiki/TracDev/ComponentArchitecture component architecture]190 See also TracGuide, [trac:PluginList plugin list], [trac:TracDev/ComponentArchitecture component architecture]
