Changes between Version 3 and Version 4 of TracAdmin
Feb 1, 2017, 12:35:30 AM (7 years ago)
  • TracAdmin
    v3 v4
    44[[TracGuideToc]]
    6 Trac is distributed with a powerful command-line configuration tool. This tool can be used  to configure and customize your Trac-installation to better fit your needs.
     6Trac is distributed with a powerful command-line configuration tool. This tool can be used to configure and customize your Trac-installation to better fit your needs.
    8 Some of those operations can also be performed via the web administration module.
     8Some of those configurations can also be performed via the web administration module.
    1010== Usage
    1111
    12 For nearly every `trac-admin` command, you'll need to specify the path to the TracEnvironment that you want to administer as the first argument, for example:
     12For nearly every `trac-admin` command, you will need to specify the path to the TracEnvironment that you want to administer as the first argument:
    1313{{{
    1414trac-admin /path/to/projenv wiki list
    1515}}}
    1616
    17 The only exception is for the `help` command, but even in this case if you omit the environment, you'll only get a very succinct list of commands (`help` and `initenv`), the same list you'd get when invoking `trac-admin` alone.
     17The only exception is for the `help` command, but even in this case if you omit the environment, you will only get a very succinct list of commands (`help` and `initenv`), the same list you would get when invoking `trac-admin` alone.
    1818Also, `trac-admin --version` will tell you about the Trac version (e.g. 0.12) corresponding to the program.
    1919
    20 If you want to get a comprehensive list of the available commands and sub-commands, you need to specify an existing environment:
     20To get a comprehensive list of the available commands and sub-commands, specify an existing environment:
    2121{{{
    2222trac-admin /path/to/projenv help
    2424
    2525Some commands have a more detailed help, which you can access by specifying the command's name as a subcommand for `help`:
    2726{{{
    2827trac-admin /path/to/projenv help <command>
    3130=== `trac-admin <targetdir> initenv` === #initenv
    3231
    33 This subcommand is very important as it's the one used to create a TracEnvironment in the specified `<targetdir>`. That directory must not exist prior to the call.
     32This subcommand is very important as is the one used to create a TracEnvironment in the specified `<targetdir>`. That directory must not exist prior to the call.
    3433
    3534[[TracAdminHelp(initenv)]]
    3837See TracIni#GlobalConfiguration.
    3938
    40 Note that in version 0.11 of Trac, `initenv` lost an extra last argument `<templatepath>`, which was used in previous versions to point to the `templates` folder. If you are using the one-liner '`trac-admin /path/to/trac/ initenv <projectname> <db> <repostype> <repospath>`' in the above and getting an error that reads ''''`Wrong number of arguments to initenv: 4`'''', then this is because you're using a `trac-admin` script from an '''older''' version of Trac.
     39Note that in version 0.11 of Trac, `initenv` lost an extra last argument `<templatepath>`, which was used in previous versions to point to the `templates` folder. If you are using the one-liner `trac-admin /path/to/trac/ initenv <projectname> <db> <repostype> <repospath>` in the above and get an error that reads `Wrong number of arguments to initenv: 4`, then this is because you are using a `trac-admin` script from an '''older''' version of Trac.
    4140
    4241== Interactive Mode
    4645(on non-Windows environments, and when the Python `readline` module is available) and automatic repetition of the last command issued.
    4746
    48 Once you're in interactive mode, you can also get help on specific commands or subsets of commands:
     47Once you are in interactive mode, you can also get help on specific commands or subsets of commands:
    4948
    5049For example, to get an explanation of the `resync` command, run:
    5150{{{
    52 > help resync
     51$ help resync
    5352}}}
    5453
    5554To get help on all the Wiki-related commands, run:
    5655{{{
    57 > help wiki
     56$ help wiki
    5857}}}
    5958
    6059== Full Command Reference
    6160
    62 You'll find below the detailed help for all the commands available by default in `trac-admin`. Note that this may not match the list given by `trac-admin <yourenv> help`, as the commands pertaining to components disabled in that environment won't be available and conversely some plugins activated in the environment can add their own commands.
     61You will find below the detailed help for all the commands available by default in `trac-admin`. Note that this may not match the list given by `trac-admin <yourenv> help`, as the commands pertaining to components disabled in that environment won't be available and conversely some plugins activated in the environment can add their own commands.
    6362
    6463[[TracAdminHelp()]]
