| 40 | | * How to create new theme : |
| 41 | | * copy the default images files under the images/ directory into your new "Sample" directory under images/themes/ |
| 42 | | * copy the default CSS stylesheet under css/ directory and rename it as Sample.css |
| 43 | | * go to the administration page -> configuration system page, then you can choose in the combo box which theme will be apply to your application |
| | 41 | [[Image(Sample_config.png)]] |
| | 42 | [[Image(Sample.png)]] |
| | 43 | |
| | 44 | === Back to default theme === |
| | 45 | |
| | 46 | [[Image(choosing_theme.png)]] |
| | 47 | |
| | 48 | === How to create new theme === |
| | 49 | * copy the default images files under the images/ directory into your new "Sample" directory under images/themes/ |
| | 50 | * copy the default CSS stylesheet under css/ directory and rename it as Sample.css |
| | 51 | * go to the administration page -> configuration system page, then you can choose in the combo box which theme will be apply to your application |
