Changes between Version 16 and Version 17 of ReplacingIntermap
- Sep 15, 2009, 12:28:42 AM (15 years ago)
ReplacingIntermap
v16 v17 12 12 Replace IM with a more responsive map client. 13 13 14 Current known initiatives : 15 * In the context of a project in Switzerland, Camptocamp team has been working on setting !MapFish as a client for catalogue. See proposal http://trac.mapfish.org/trac/mapfish/wiki/Proposals/Catalogue 16 * NGR (http://www.nationaalgeoregister.nl/geonetwork/srv/nl/main.home) 17 * Mali (Jean) - start from geocat.ch 18 * MEDWIP (http://www.emwis.net/geonetwork/) 19 20 21 === Some screenshots === 22 23 [[Image(GeoNetworkOpenLayerMapFish.png, 450)]] 24 14 15 === Some screenshots & suggestions === 16 ==== geocat.ch sandbox ==== 17 [[Image(geocat-home.png, 450)]] 18 [[Image(geocat-popup.png, 450)]] 19 20 ==== NGR ==== 21 * http://www.nationaalgeoregister.nl/geonetwork 25 22 26 23 [[Image(ngr-search.png, 450)]] … … 28 25 [[Image(ngr-map.png, 450)]] 29 26 30 27 ==== Geoportal in Mali (Jean Pommier) === 31 28 [[Image(gdtmali-home.png, 450)]] 32 29 [[Image(gdtmali-search.png, 450)]] 33 30 [[Image(gdtmali-compare-maps.png, 450)]] 34 31 35 36 [[Image( geocat-home.png, 450)]]37 38 39 32 ==== Dummy prototype ==== 33 [[Image(GeoNetworkOpenLayerMapFish.png, 450)]] 34 35 ==== MEDWIP ==== 36 * http://www.emwis.net/geonetwork/ 40 37 41 38 … … 49 46 * '''Email discussions''': 50 47 * '''Other wiki discussions''': 48 * http://logs.qgis.org/geonetwork/%23geonetwork.2009-09-01.log 51 49 52 50 === Voting History === … … 65 63 * add support for some Intermap missing functionnalities: 66 64 * allow simple vector feature support (bbox highlight, define bbox or bounding polygon in the editor) 67 * allow non WGS84 projection support 65 * allow non WGS84 projection support and use proj4js to reproject vector feature when needed 66 * using non WGS84 projection could still raise issue when user add a WMS layer from a remote service which does not support the client projection 68 67 * improve : 69 68 * map viewing (tiling, layer tree) … … 81 80 * simple search form 82 81 * full text 83 * region or bounding box82 * region (list of values) or bounding box 84 83 * INSPIRE : annex I, II, III * 85 84 * INSPIRE : Discovery, View, Download, Transform, Invoke, Other … … 102 101 * For all INSPIRE parameters a config file parameter should allow to turn it on/off 103 102 104 Autocompletion is made using GetDomain operation.103 Autocompletion or list of values is made using GetDomain operation. 105 104 106 105 === Catalogue search results === … … 114 113 * Massive actions 115 114 Example: 116 {{{ 117 Aggregate Results matching search criteria: 1-10 / 1888 118 Next > | 0 selected | Select: all, none 119 }}} 115 [[Image(search-results-header.png)]] 116 120 117 * Search results: 121 118 * small view: … … 130 127 * thumbnail 131 128 * icons (see NGR) 129 [[Image(search-results-mediumout.png)]] 130 132 131 * thumbnail 133 132 * group logo 134 133 * title 135 134 * thumbnail 135 [[Image( search-results-thumbnailout.png)]] 136 136 137 137 138 Actions: … … 161 162 || '''Function''' || Available in 2.2 || geocat.ch || NGR || Available || Comments || 162 163 || Metadata Bbox higlighter || || X || || 164 || Current view bounds is used for bbox search || || X || || 163 165 164 166 ==== Big-map features ==== 165 167 || '''Function''' || Available in 2.2 || geocat.ch || NGR || Available || Comments || 166 || Layer tree || X || X || || || GeoExt layer tree (add, remove, view, reorder, transparency) || 167 || Pdf printing || X || X || || || MapFish print module, TODO send by email || 168 || WMC || X || X || || || OL WMC support, TODO email context || 169 168 || Get feature info || X || || X || || || 169 || Layer tree || X || X || X || || GeoExt layer tree (add, remove, view, reorder, transparency) || 170 || Pdf printing || X || X || X || || || 171 || WMC || X || || X || || || 172 || previous/next view || || || X || || || 170 173 171 174 ==== Intermap feature not available in the proposal ====
