Changes between Version 10 and Version 11 of PerformanceEnhancements
Mar 5, 2010, 7:49:38 AM (14 years ago)
simonp
  • PerformanceEnhancements
    v10 v11
    4343      * multiple threads to schedule documents that need to be written to the index without blocking
    4444
    45  * Speeding up spatial indexing using PostGIS: !GeoNetwork uses a shapefile to hold spatial extents for searches that contain spatial queries eg. touch, intersect, contains, overlap etc. At present only the CSW service uses the spatial index for these queries, the web search interface uses boxes and !Lucene. The spatial index needs to be maintained when records are added and deleted through import, harvesting, massive delete etc. Unfortunately the shapefile is not efficient for this purpose as the number of records in the catalog goes over 40,000 odd. In particular as the mechanism for deleting extents from the shapefile uses an attribute of the extent and these are not indexable meaning that there is a considerable cost for maintenance operations on the shapefile. To support fast maintenance and search of the spatial index for larger catalogs, it was decided to adopt the PostGIS implementation for the spatial index written for the geocat.ch sandbox by Jessie Eichar and to fall back to using a shapefile when the catalog is not using PostGIS for its database. An option has been added to GAST to allow the user to specify PostGIS as the database and to build the spatial index table when the Database->Setup option is used. When !GeoTools 2.6.x is adopted, we will very likely also allow the spatial index in !Oracle for those who must use that.
     45 * Speeding up spatial indexing using PostGIS: !GeoNetwork uses a shapefile to hold spatial extents for searches that contain spatial queries eg. touch, intersect, contains, overlap etc. At present only the CSW service uses the spatial index for these queries, the web search interface uses boxes and !Lucene. The spatial index needs to be maintained when records are added and deleted through import, harvesting, massive delete etc. Unfortunately the shapefile is not efficient for this purpose as the number of records in the catalog goes over 40,000 odd. In particular as the mechanism for deleting extents from the shapefile uses an attribute of the extent and these are not indexable meaning that there is a considerable cost for maintenance operations on the shapefile. To support fast maintenance and search of the spatial index for larger catalogs, it was decided to adopt the PostGIS implementation for the spatial index written for the geocat.ch sandbox by Jessie Eichar and to fall back to using a shapefile when the catalog is not using PostGIS for its database. An option has been added to GAST to allow the user to specify PostGIS as the database and to build the spatial index table when the Database->Setup option is used. When !GeoTools 2.6.x is adopted, we will very likely be able to also allow the spatial index in Oracle for those who must use that.
    4646
    4747The net result of these two fixes is much faster load, harvest, reindex and massive operations in !GeoNetwork. For example, in one case doing a file system harvest of 20,000 records was taking 10-12 hours without these modifications. With the modifications described in this proposal, the same harvest now takes approx 30 minutes.
