Changes between Version 14 and Version 15 of MetadataSiblings
- Sep 19, 2012, 10:23:16 PM (12 years ago)
MetadataSiblings
v14 v15 66 66 * in the java code underlying the !GetRelated guiservice. A simple XPath extraction for all aggregateInformation elements that have an aggregateDataSetIdentifier with a code, an associationType with value set to crossReference and an initiativeType is used to assemble the list of codes (UUIDs/URNs). Sibling metadata records are extracted from the database and attached to the XML output of the !GetRelated guiservice. 67 67 * add processing of the !GetRelated output in relations.xsl which is used in the xml.relation service - returns a simple/brief view of the related records. 68 * add processing of related sibling records from guiservice to iso19139/present/metadata-iso19139-utils.xsl - this XSLT generates the classic presentation of related records - see below .68 * add processing of related sibling records from guiservice to iso19139/present/metadata-iso19139-utils.xsl - this XSLT generates the classic presentation of related records - see below (Note that the same record is used as a parent and as a 'project' sibling). 69 69 [[Image(ClassicSiblingRelationships.png)]] 70 70 * add processing of related sibling records from xml.relations to the ExtJS !MetadataRelationStore.js and the ExtJS user interface - see below.
