Changes between Version 8 and Version 9 of Maven
- Mar 31, 2010, 2:28:26 AM (14 years ago)
Maven
v8 v9 35 35 * GeoServer : no more embedded in GeoNetwork (should be a dependency). 36 36 * CSW client : removed 37 * Jetty : removed and started using Maven (see Run the application) 38 * Installer : TODO (Ant or assembly ?) 37 * Jetty : removed and start the web application using Maven related plugins (see Run the application) 38 * Installer : 39 * assembly plugin is used to create a ZIP package with licence and war files 40 * TODO : create a binary version with Jetty ? installer ? 39 41 * OAI-PMH dependencies 40 42 * Duplicate iso date class to fix cyclic reference. 41 43 * Test : removed 42 * to fix cyclic reference with GAST. Test also required a Jetty embedded which is not a good option. 43 * Unit test or test against a running app could be added. 44 * removed to fix cyclic reference with GAST. 45 * Actual tests also require a Jetty embedded which has been removed (test was starting Jeeves, to run test). 46 * TODO : Unit test or test against a running app could be added. 44 47 * GAST : 45 48 * GAST was using only the application path to load both resources and libs (from WEB-INF/lib). Added a libPath and an appPath. … … 93 96 mvn eclipse:eclipse 94 97 }}} 95 TODO : multiple project setup96 98 97 99 … … 99 101 * GAST : 100 102 * FIXME / hardcoded classpath in MANIFEST 101 * What to do with GAST ? 102 103 * What to do with GAST and embedded jetty and mckoi ? 103 104 104 105 === Proposal Type ===
