Changes between Version 8 and Version 9 of HowToViewSpatialIndexUsingGeoServerWMS
Dec 21, 2009, 8:46:19 PM (14 years ago)
terryrankine
  • HowToViewSpatialIndexUsingGeoServerWMS
    v8 v9
    1010Note: Occasionally a lock issue on the Shapefile occurs when both !GeoNetwork and !GeoServer try to access the file. This causes Geoserver to lose the configuration for the shapefile. A better option could be to make a copy of the files on a regular basis or use Geoserver's RESTful interface
    1111
    12 UPDATE: If your using geoserver 2.x and you cant get it to detect the shape file or shapefile directory - leave `data/` out from the paths shown in the screen shots.
     12'''UPDATE: ''' If your using geoserver 2.x and you cant get it to detect the shape file or shapefile directory - leave `data/` out from the paths shown in the screen shots.
    1313
    1414
