Changes between Version 6 and Version 7 of HowToViewSpatialIndexUsingGeoServerWMS
- Dec 21, 2009, 8:44:55 PM (14 years ago)
v6 v7 9 9 10 10 Note: Occasionally a lock issue on the Shapefile occurs when both !GeoNetwork and !GeoServer try to access the file. This causes Geoserver to lose the configuration for the shapefile. A better option could be to make a copy of the files on a regular basis or use Geoserver's RESTful interface 11 12 UPDATE: If your using geoserver 2.x and you cant get it to detect the shape file or shapefile directory - leave =data/= out from the paths shown in the screen shots. 11 13 12 14
