Changes between Version 15 and Version 16 of HowToRunUnderTomcat
- Sep 8, 2009, 8:31:47 PM (15 years ago)
HowToRunUnderTomcat
v15 v16 47 47 a. In `/etc/init.d/tomcatXXX` set 'TOMCATXXX_SECURITY' (XXX = Tomcat version) parameter to 'no'. 48 48 1. Edit Tomcat's `server.xml` to set parameters as you wish. 49 1. If you can't find you log files, make sure you edit `/...path_to_GeoNetwork_installation_goes_here.../web/geonetwork/WEB-INF/log4j.cfg`:49 1. If you can't find your log files, make sure you edit `/...path_to_GeoNetwork_installation_goes_here.../web/geonetwork/WEB-INF/log4j.cfg`: 50 50 a. Change 'log4j.appender.jeeves.file' to '/var/log/tomcatXXX/geonetwork.log' (XXX = Tomcat version) or wherever you want to have your logs. 51 51 1. Start Tomcat.
