Changes between Version 5 and Version 6 of HowToRunUnderJettyInEclipse
- Jan 21, 2010, 3:20:35 AM (14 years ago)
v5 v6 40 40 === Issues === 41 41 * I'm still looking how to redirect all logs info (including geonetwork.log) to the eclipse console view. 42 43 * If you have some errors about classes not available due to access restrictions ("Access restriction: The type BASE64Encoder is not accessible due to restriction on required library" for example), just go to the "Window" / "Preferences" / "Java" / "Compiler" / "Errors/Warnings" menu and then set "Forbidden reference (access rules)" to "Warning" or "Ignore" instead of "Error". 44
