Changes between Version 1 and Version 2 of Fr_HowToMigrateTo23
Apr 11, 2010, 11:48:07 PM (14 years ago)
fxp
  • Fr_HowToMigrateTo23
    v1 v2
    2525INSERT INTO Settings VALUES (90, 1, 'selectionmanager', null);
    2626INSERT INTO Settings VALUES (91, 90, 'maxrecords', 1000);
    27 INSERT INTO Settings VALUES (170,1,'shib,'');
    28 INSERT INTO Settings VALUES (171,170,'use,'false');
    29 INSERT INTO Settings VALUES (172,170,'path,'/geonetwork/srv/en/shib.user.login');
    30 INSERT INTO Settings VALUES (173,170,'attrib,'');
    31 INSERT INTO Settings VALUES (174,173,'username,'REMOTE_USER');
    32 INSERT INTO Settings VALUES (175,173,'surname,'Shib-Person-surname');
    33 INSERT INTO Settings VALUES (176,173,'firstname,'Shib-InetOrgPerson-givenName');
    34 INSERT INTO Settings VALUES (177,173,'profile,'Shib-EP-Entitlement');
    35 INSERT INTO Settings VALUES (190,1,'userSelfRegistration,'');
    36 INSERT INTO Settings VALUES (191,190,'enable,'false');
    37 INSERT INTO Settings VALUES (200,1,'clickablehyperlinks,'');
    38 INSERT INTO Settings VALUES (201,200,'enable,'true');
    39 INSERT INTO Settings VALUES (210,1,'localrating,'');
    40 INSERT INTO Settings VALUES (211,210,'enable,'false');
    41 INSERT INTO Settings VALUES (220,1,'xlinkResolver,'');
    42 INSERT INTO Settings VALUES (221,220,'enable,'true');
    43 INSERT INTO Settings VALUES (600,1,'indexoptimizer,'');
    44 INSERT INTO Settings VALUES (601,,'600,'enable,'true');
    45 INSERT INTO Settings VALUES (602,600,'at,'');
    46 INSERT INTO Settings VALUES (603,602,'hour,'0');
    47 INSERT INTO Settings VALUES (604,602,'min,'0');
    48 INSERT INTO Settings VALUES (605,602,'sec,'0');
    49 INSERT INTO Settings VALUES (606,600,'interval,'');
    50 INSERT INTO Settings VALUES (607,606,'day,'0');
    51 INSERT INTO Settings VALUES (608,606,'hour,'24,'');
    52 INSERT INTO Settings VALUES (609,606,'min,'0');
     27INSERT INTO Settings VALUES (170,1,'shib','');
     28INSERT INTO Settings VALUES (171,170,'use','false');
     29INSERT INTO Settings VALUES (172,170,'path','/geonetwork/srv/en/shib.user.login');
     30INSERT INTO Settings VALUES (173,170,'attrib','');
     31INSERT INTO Settings VALUES (174,173,'username','REMOTE_USER');
     32INSERT INTO Settings VALUES (175,173,'surname','Shib-Person-surname');
     33INSERT INTO Settings VALUES (176,173,'firstname','Shib-InetOrgPerson-givenName');
     34INSERT INTO Settings VALUES (177,173,'profile','Shib-EP-Entitlement');
     35INSERT INTO Settings VALUES (190,1,'userSelfRegistration','');
     36INSERT INTO Settings VALUES (191,190,'enable','false');
     37INSERT INTO Settings VALUES (200,1,'clickablehyperlinks','');
     38INSERT INTO Settings VALUES (201,200,'enable','true');
     39INSERT INTO Settings VALUES (210,1,'localrating','');
     40INSERT INTO Settings VALUES (211,210,'enable','false');
     41INSERT INTO Settings VALUES (220,1,'xlinkResolver','');
     42INSERT INTO Settings VALUES (221,220,'enable','true');
     43INSERT INTO Settings VALUES (600,1,'indexoptimizer','');
     44INSERT INTO Settings VALUES (601,600,'enable','true');
     45INSERT INTO Settings VALUES (602,600,'at','');
     46INSERT INTO Settings VALUES (603,602,'hour','0');
     47INSERT INTO Settings VALUES (604,602,'min','0');
     48INSERT INTO Settings VALUES (605,602,'sec','0');
     49INSERT INTO Settings VALUES (606,600,'interval','');
     50INSERT INTO Settings VALUES (607,606,'day','0');
     51INSERT INTO Settings VALUES (608,606,'hour','24');
     52INSERT INTO Settings VALUES (609,606,'min','0');
    5353
    5454}}}
    5555
    5656TODO : Vérifier les interactions avec les noeuds moissonnés (problème d'identifiant)
     57
     58==== McKoi =====
     59===== Connexion à la base de données =====
     60 * Télécharger l'utilitaire Druid (http://druid.sourceforge.net/)
     61 * Lancer Druid (java -jar druid.jar)
     62 * Ouvrir le fichier database.druid situé dans le répertoire gast/setup de GeoSource 2.2
     63 * Dans l'onglet JDBC > Connection,
     64  * saisir les informations de connexion pour la base utilisée par GeoSource 2.2
     65  * cocher l'option autocommit
     66  * cliquer sur connecter
     67
     68===== Sauvegarde ====
     69 * Dans l'onglet structure, faire une sauvegarde de la base :
     70  * clic droit sur "JDBC database" > "Export records ..."
     71  * sélectionner "Druid data format"
     72  * sélectionner un répertoire
     73  * un fichier par table est alors créé.
     74
     75===== Migration ====
     76
     78==== MySQL ====
     79
     80==== PostGresql ====
     81
     82==== Oracle ====
     83
    5784
    5885
