Changes between Initial Version and Version 1 of CSWebRIMXSD
Dec 2, 2008, 6:03:06 AM (15 years ago)
heikki
  • CSWebRIMXSD
     1 {{{
     3<xsd:schema xmlns:wrs="http://www.opengis.net/cat/wrs/1.0" xmlns:rim="urn:oasis:names:tc:ebxml-regrep:xsd:rim:3.0" xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:sch="http://www.ascc.net/xml/schematron" targetNamespace="http://www.opengis.net/cat/wrs/1.0" elementFormDefault="qualified" version="1.0.0" id="csw-ebrim">
     4        <xsd:annotation>
     5                <xsd:appinfo>
     6                        <sch:pattern id="ComplexSlotValuesPattern" name="ComplexSlotValuesPattern">
     7                                <sch:rule context="//wrs:ValueList">
     8                                        <sch:report test="rim:Value">rim:Value not allowed in this context: expected wrs:AnyValue.</sch:report>
     9                                </sch:rule>
     10                        </sch:pattern>
     11                </xsd:appinfo>
     12                <xsd:documentation xml:lang="en"> Schema for CSW-ebRIM catalogue profile (OGC 07-110r2). </xsd:documentation>
     13        </xsd:annotation>
     14        <xsd:import namespace="http://www.opengis.net/cat/csw/2.0.2" schemaLocation="http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd"/>
     15        <xsd:import namespace="urn:oasis:names:tc:ebxml-regrep:xsd:rim:3.0" schemaLocation="http://docs.oasis-open.org/regrep/v3.0/schema/rim.xsd"/>
     16        <xsd:import namespace="http://www.w3.org/1999/xlink" schemaLocation="http://schemas.opengis.net/xlink/1.0.0/xlinks.xsd"/>
     17        <xsd:import namespace="http://www.opengis.net/ogc" schemaLocation="http://schemas.opengis.net/filter/1.1.0/filter.xsd"/>
     18        <xsd:element name="Capabilities" type="csw:CapabilitiesType"/>
     19        <xsd:element name="RecordId" type="wrs:RecordIdType" substitutionGroup="ogc:_Id" id="RecordId">
     20                <xsd:annotation>
     21                        <xsd:documentation xml:lang="en"> A general record identifier, expressed as an absolute URI that maps to the rim:RegistryObject/@id attribute. It substitutes for the ogc:_Id element in an OGC filter expression. </xsd:documentation>
     22                </xsd:annotation>
     23        </xsd:element>
     24        <xsd:complexType name="RecordIdType" id="RecordIdType" mixed="true">
     25                <xsd:complexContent mixed="true">
     26                        <xsd:extension base="ogc:AbstractIdType"/>
     27                </xsd:complexContent>
     28        </xsd:complexType>
     29        <xsd:element name="ExtrinsicObject" type="wrs:ExtrinsicObjectType" substitutionGroup="rim:ExtrinsicObject"/>
     30        <xsd:complexType name="ExtrinsicObjectType">
     31                <xsd:annotation>
     32                        <xsd:documentation xml:lang="en"> Extends rim:ExtrinsicObjectType to add the following: 1. MTOM/XOP based attachment support. 2. XLink based reference to a part in a multipart/related message structure. NOTE: This is planned for RegRep 4.0. </xsd:documentation>
     33                </xsd:annotation>
     34                <xsd:complexContent>
     35                        <xsd:extension base="rim:ExtrinsicObjectType">
     36                                <xsd:choice minOccurs="0">
     37                                        <xsd:element name="repositoryItemRef" type="wrs:SimpleLinkType"/>
     38                                        <xsd:element name="repositoryItem" type="xsd:base64Binary" xmime:expectedContentTypes="*/*"/>
     39                                </xsd:choice>
     40                        </xsd:extension>
     41                </xsd:complexContent>
     42        </xsd:complexType>
     43        <xsd:element name="ValueList" type="wrs:ValueListType" substitutionGroup="rim:ValueList"/>
     44        <xsd:complexType name="ValueListType">
     45                <xsd:annotation>
     46                        <xsd:documentation xml:lang="en">Allows complex slot values.</xsd:documentation>
     47                </xsd:annotation>
     48                <xsd:complexContent>
     49                        <xsd:extension base="rim:ValueListType">
     50                                <xsd:sequence minOccurs="0" maxOccurs="unbounded">
     51                                        <xsd:element ref="wrs:AnyValue"/>
     52                                </xsd:sequence>
     53                        </xsd:extension>
     54                </xsd:complexContent>
     55        </xsd:complexType>
     56        <xsd:element name="AnyValue" type="wrs:AnyValueType"/>
     57        <xsd:complexType name="AnyValueType" mixed="true">
     58                <xsd:sequence>
     59                        <xsd:any minOccurs="0"/>
     60                </xsd:sequence>
     61        </xsd:complexType>
     62        <xsd:complexType name="SimpleLinkType" id="SimpleLinkType">
     63                <xsd:annotation>
     64                        <xsd:documentation xml:lang="en"> Incorporates the attributes defined for use in simple XLink elements. </xsd:documentation>
     65                </xsd:annotation>
     66                <xsd:attributeGroup ref="xlink:simpleLink"/>
     67        </xsd:complexType>
     68</xsd:schema>
     69
     70 }}}
