Changes between Version 28 and Version 29 of Bolsena2010
- Apr 1, 2010, 9:35:06 PM (14 years ago)
Bolsena2010
v28 v29 74 74 * GeoNetwork lacks the ability to consistently reproduce a unique identifier for the same geo resource (e.g. same dataset stored in two different locations) and/or use persistent identifier services. This is somewhere along the range from "easy enough" to "very difficult", need to spell out the precise details of the set of features you have in mind. Action: GeoNetwork needs to be able to generate, store and use metadata identifiers (eg, gmd:fileIdentifier) as well as data identifiers using the current stand alone UUID, but also (for data objects) MD5 (including what the checksum was generated from) and identifiers from external persistent identifier services (It should be possible to obtain persistent identifiers for both metadata and data from external persistent identifier services). 75 75 76 * Better inter-application interoperability. GeoNetwork needs to rethink the interoperability with the emerging FOSS such as the way that OpenLayers is designing / redeveloping its interface. 77 e.g. use of GeoExt; e.g. GeoNetwork needs to provide simple mechanisms to allow discovered resources to be exploited and utilised in complementary open source software; e.g. drag-and-drop discovered resources into OpenLayers or GeoServer. Action: Better intra-application interoperability. GeoNetwork needs to coordinate the discovery of resources with the publication of those same resources in FOSS such as GeoServer. 76 * Better inter-application interoperability. GeoNetwork needs to rethink the interoperability with the emerging FOSS such as the way that OpenLayers is designing / redeveloping its interface. e.g. use of GeoExt; e.g. GeoNetwork needs to provide simple mechanisms to allow discovered resources to be exploited and utilised in complementary open source software; e.g. drag-and-drop discovered resources into OpenLayers or GeoServer. Action: Better intra-application interoperability. GeoNetwork needs to coordinate the discovery of resources with the publication of those same resources in FOSS such as GeoServer. 78 77 79 78 * GeoNetwork assumes resources that are tagged as data for download in gmd:protocol are local. Action: GeoNetwork needs to allow for the fact that data tagged as data for download may not be local.
