Changes between Initial Version and Version 1 of 115and139Confusion
Apr 2, 2007, 1:22:10 PM (17 years ago)
ticheler
  • 115and139Confusion
     1= The ISO-19115 & ISO-19139 confusion =
     3The ISO19115-19139 standards seem to confuse many, many people. Here's a short attempt to clarify the situation :-)
     4There is only one (1!) metadata standard for geographic data, and that is the ISO-19115 metadata standard. The ISO-19115 standard was originally released without a DTD or XML schema that could be used to validate such a metadata record (formatted as an XML document). It was decided by ISO TC211 to develop a specific implementation standard, called ISO-19139. This standard would have the form of a metadata scheme (an XSD document). The schema can be used to validate the structure of an ISO-19115 document. It has taken a long time for a good 19139 schema to be released. A final schema is still not available to date (04-2007).
     6To confuse things more, many software started implementing different versions of the ISO-19115 standard :( The !GeoNetwork development team decided back in 2002 to use the Draft International Standard version of ISO-19115 (ISO-19115:DIS). This version of the standard (not yet standard at that point) provided a DTD and was as such the only version that could have a formal checking of its structure. !GeoNetwork used (and still supports) short element names in its XML representation.
     8For !GeoNetwork 2.1 we have now created a migration procedure to convert the ISO-19115:DIS formatted metadata into a structure that complies with the formal ISO-19115:2003 standard and that validates against the ISO-19139 schema as [http://eden.ign.fr/xsd/isotc211/20060504 released on 4 May 2006] referred to as 'final Release candidate for TS'.
     10GeoNetwork opensource still supports the 19115:DIS format for backward compatibility, but it is foreseen that that format will be less exposed to users to facilitate transition to the new format and avoid a bit of confusion :-)
