Changes between Version 3 and Version 4 of TracSyntaxColoring
May 8, 2022, 3:10:54 PM (2 years ago)
  • TracSyntaxColoring
    v3 v4
    11= Syntax Coloring of Source Code
    2 Trac supports language-specific syntax highlighting of source code within wiki formatted text in [WikiProcessors#CodeHighlightingSupport wiki processors] blocks and in the [TracBrowser repository browser]. Syntax coloring is provided using [http://pygments.org/ Pygments], which covers a wide range of programming languages and other structured texts, and is actively supported. If Pygments is not available, Trac will display the content as plain text.
     2Trac supports language-specific syntax highlighting of source code within wiki formatted text in [WikiProcessors#CodeHighlightingSupport wiki processors] blocks and in the [TracBrowser repository browser]. Syntax coloring is provided using [http://pygments.org/ Pygments], which covers a wide range of programming languages and other structured texts, and is actively supported. If Pygments is not available, Trac will display the content as plain text.
    5 === About Pygments
     4== About Pygments
    65
    76[http://pygments.org/ Pygments] is a highlighting library implemented in pure python, very fast, easy to extend and [http://pygments.org/docs/ well documented].
    87
    9 The Pygments default style can specified in the [TracIni#mimeviewer-section mime-viewer] section of trac.ini. The default style can be overridden by setting a //Style// preference on the [/prefs/pygments preferences page].
     8The Pygments default style can specified in the [TracIni#mimeviewer-section mime-viewer] section of trac.ini. The default style can be overridden by setting a //Style// preference on the [/prefs/pygments preferences page].
    109
    1110[http://pygments.org/docs/lexers/ Pygments lexer] options can be specified as [WikiProcessors WikiProcessor] arguments and defaults can be set in the [TracIni#pygments-lexer-section environment configuration].
    1716The list of currently supported languages can be found on the [http://pygments.org/languages/ supported languages] page. The list represents the languages supported in the most recent version of Pygments, so the languages actually supported in your installation could differ if you have an older version installed. The listing of [http://pygments.org/docs/lexers/ supported lexers] provides additional information about the default mime type to keyword mappings.
    1817
    19 Explicit control of the mime type associated with a [WikiProcessors WikiProcessor] and file extension is available through the `mime_map` setting. For example, by default `.m` files are considered Objective-C files. In order to treat `.m` files as MATLAB files, add `text/matlab:m` to the `mime_map` setting in the [wiki:TracIni#mimeviewer-section "[mimeviewer] section of trac.ini"].
     18Explicit control of the mime type associated with a [WikiProcessors WikiProcessor] and file extension is available through the `mime_map` setting. For example, by default `.m` files are considered Objective-C files. In order to treat `.m` files as MATLAB files, add `text/matlab:m` to the [wiki:TracIni#mimeviewer-mime_map-option "[mimeviewer] mime_map"] option.
    2019
    2120If a mimetype property such as `svn:mime-type` is set to `text/plain`, there is no coloring even if file is known type like `java`.
    2322=== Direct Rendering
    2423
    25 Rich content may be directly //rendered// instead of syntax highlighted. This usually depends on which auxiliary packages are installed and on which components are activated in your setup. For example a `text/x-rst` document will be rendered via `docutils` if it is installed and the `trac.mimeview.rst.ReStructuredTextRenderer` is not disabled, and will be syntax highlighted otherwise.
     24Rich content may be directly //rendered// instead of syntax highlighted. This usually depends on which auxiliary packages are installed and which components are activated in your setup. For example, a `text/x-rst` document will be rendered via `docutils` if it is installed and the `trac.mimeview.rst.ReStructuredTextRenderer` is not disabled. It will be syntax highlighted otherwise.
    2625
    27 Similarly, a document with the mimetype `text/x-trac-wiki` is rendered using the Trac wiki formatter, unless the `trac.mimeview.api.WikiTextRenderer` component is disabled.
     26Similarly, a document with the mimetype `text/x-trac-wiki` is rendered using the Trac wiki formatter, unless the `trac.mimeview.api.WikiTextRenderer` component is disabled. If you want to ensure that an HTML document gets syntax highlighted and not rendered, use the `text/xml` mimetype.
    2827
    29 HTML documents are directly rendered only if the `render_unsafe_html` settings are enabled in your TracIni file. Those settings are present in multiple sections, as there are different security concerns depending where the document comes from. If you want to ensure that an HTML document gets syntax highlighted and not rendered, use the `text/xml` mimetype.
     28HTML documents are directly rendered only if the `render_unsafe_html` settings are enabled in your TracIni file. See [TracIni#attachment-render_unsafe_content-option "[attachment] render_unsafe_content"], [TracIni#browser-render_unsafe_content-option "[browser] render_unsafe_content"] and [TracIni#wiki-render_unsafe_content-option "[wiki] render_unsafe_content"]. The setting is present in multiple sections because there are different security concerns depending on where the document comes from.
    3029
    3130=== Known MIME types
